INT: honda Prelude steering wheel conversion on 90-91 cb
    This diy thread is to show you a way to install the 88-91 Honda prelude steering wheel into the 90-91 Honda accord.
    Things you will need:
    ----88-91 Prelude steering wheel and clock spring.
    ----- 18mm socket and a ratchet w/ an extension
    ----- Phillips screw driver
    ----- Small flat head screw driver
    ----- Wire cutter
    ----- blade
    ----- Soldering gun and elect. tape
    ----- Sand paper with sanding block or 7 1/8" thick washers.
    Instructions:
    1---Start by taking the H center cap off with the small flat head screwdriver.
    2---With the 18mm socket take out the nut....there will be a wire-socket connected to the back of the steering wheel so take out the steering wheel slowly about 2 inches and disconnect the wire.
    3---Take out the cover behind the wheel, it has 4 screws under (Phillips screw driver for this)
    4---Unscrew the clock spring (4 screws)
    5---Cut all three wires ONE AT A TIME on the cb7 and the prelude harness (solder them or tape them according to their colors)
    6----Place and screw the clock spring back onto the cb7.
    7----Place and screw the cover back.
    8----Sand the front of the cover so that the prelude steering wheel wont rub against it......or just place the 7 washers.
    9----Slide the prelude steering wheel back on and connect the wire socket to the clock spring.
    10---Tighten the 18mm nut.
    11---Test out to see if the horn works and if the steering wheel does not rub.
    note: since i deleted the cruise control, joshy went ahead and made me a delete plate thus replacing the cruise control buttons from the prelude steering wheel.
    12---enjoy
    Here are some installation images...
    This is for ALL those wanting to this particular swap and was not able to OR had to ask a couple other Members' on here (to include street_beauty90) numerous questions.
    Excellent write-up! Cannot get any easier than this!!!
    BTW, this car is definitely a thing of beauty with all the nuks n crannies.
    T.
    RETIRED...
      Fucking nice..
      does the Turn signals turn off? not like Aftermarket ebay ones?
      horn work too????
      PROPS
      Ride: 2002 Lexus IS300
        everything works like nothing happened
          EVERYTHING works
          RETIRED...
            T.
            thanks for the props, i owe it all to trev, if it wasnt for him i would have never done this.
              Nah bro, you deserve ALL the credit. I just pressured you to go to the yard that's all.
              RETIRED...
                lol yeah thats true, if i wouldnt have gone i would have never found these!!!!
                  Nice that's great! I really like that, yet still OE! SWeet! Good write up.
                  Proud owner of the only JJDM full 2.5" catback exhaust!
                    Nice rims..how much you pick those up for?
                      thanks ive been looking for these rims for a while now, but i guess i never thought i would find them in a junk yard, i paid 160 for them, ima clean them good and i will post some pics once i put some wheels on them
                        The way you put the wires together is a fire waiting to happen.
                          true, i know one of them is for the horn, as for the other two they are for the cruise control, i will take the fuse out tomorrow because i lost my cruise control due to the swap, i think that should solve the prob,
                            word ! Everything always seems to fall in place for me on this site. I just started thinking about this today when I was looking at a friends lude. Sure enough, I get back to my dorm, and this was made.
                            Great write up bro.
                              do 90-91's have air bags?
                              93 SE F22A6
