Old 08-15-2008, 09:53 PM   #1
bcjammerx
bcjammerx seems to have made some friends!
Send a message via AIM to bcjammerx Send a message via Yahoo to bcjammerx
When window rolls up, crooked glass, glass sticks out
found this thread
http://www.cb7tuner.com/vbb/showthre...crooked+window
and there was not a straight answer, didn't find anything else with my search.
With the link given in that site (here), to fix that specific problem (crooked window glass, glass sticks out when rolled up) I would need part 15, correct? Also, would I need the two sashes, parts 13-14, as well? I imagine after 15 years those sashes may be pretty worn.
and for the rear windows (link), to fix a wind noise issue I would needs parts 5, 6, 7, and 8 (for the right side that is)?
____
bcjammerx is offline   Reply With Quote
Old 08-16-2008, 02:08 AM   #2
Night Wolf
Night Wolf seems to have made some friends!
Send a message via AIM to Night Wolf
if its the front the bolts for the regulator might be a bit loose
if its the back the bolts that hold glass to the center arm might be loose
as for the glass popping out, make sure the weather seal isnt cut anywhere
93 Accord LX Sedan (sold)-01 Civic LX Sedan (sold)-93 Accord EX Wagon (totaled)
93 Accord SE Sedan (sold)-95 Accord LX Wagon (CURRENT)-92 Accord EX Sedan (sold)
93 Accord SE Coupe (sold)-97 Accord SiR Wagon (CURRENT)-05 Impreza WRX Sedan-(CURRENT)
Night Wolf is offline   Reply With Quote
Old 08-16-2008, 07:48 AM   #3
alexsaccord
alexsaccord is cool... so far.
I had the same problem in our high mileage car. I changed out the glass channel it worked for awhile and did it again, so out of frustration I sprayed the crap out of the window rubbers with silicone spray, solved the problem. I give it a spray every month now.
alexsaccord is offline   Reply With Quote
Old 08-16-2008, 11:48 AM   #4
xkjnboix
xkjnboix seems to have made some friends!
Send a message via AIM to xkjnboix
the answer is your window seals. i did the same thing with the silicone spray. solved the problem till you have time to tackle the door seal. the seal thats vertical closest to your engine bay is the problem most likely at least it was in mine. the door rubber gets old and kinda shrinks after a while i ripped mine out and then i put it back. made a few snips in the rubber that was all kinda bunched up and has worked fine for about 2 years. im starting to have issues again but not major like before. but the spray takes care of it.
[color="Magenta"]
xkjnboix is offline   Reply With Quote
Old 08-16-2008, 12:10 PM   #5
Straight Success
Straight Success seems to have made some friends! Straight Success seems to have made some friends!
I always thought that was a window regulator problem.
The Lord watches over me!
"...never let them know your next move..."
- Christopher "Frank White" Wallace
Straight Success is offline   Reply With Quote
Old 08-16-2008, 04:37 PM   #6
bcjammerx
well the seal is broken so it will need to be replaced. I will replace it and go from there, I suppose that will be all I need then. Thanks all!
____
Old 08-17-2008, 09:46 PM   #7
Black_Soul
Black_Soul is cool... so far.
Send a message via Yahoo to Black_Soul
what you can do is get the window visers that go over all your windows
this should take care of that problem
underground Society 757
Black_Soul is offline   Reply With Quote
Old 08-17-2008, 10:01 PM   #8
bcjammerx
This will not make my window not roll up crooked or stick out from the molding. This may cover the glass, but it does not fix anything.
I don't get water leaking in or anything like that...just wind noise and crookedness. Well water CAN get in, but it usually doesn't get in that small hole. And if it rains, I can pull back on the glass with the palm of my hand and make it roll up mostly right, no more gap.
____
Old 08-17-2008, 10:03 PM   #9
C91BLX7
C91BLX7 is very helpful C91BLX7 is very helpful C91BLX7 is very helpful
Window seal.
wat?
C91BLX7 is offline   Reply With Quote
Old 08-24-2008, 07:23 PM   #10
Black_Soul
try to get a new molding from a junk yard clean it and it should work
Old 08-24-2008, 07:28 PM   #11
F22HB
F22HB is cool... so far.
Send a message via AIM to F22HB
Got this problem as well. When I got the car it didn't roll up so I replaced the motor and it rolled up but now it pops out kinda crooked unless I help it.
F22HB is offline   Reply With Quote
Old 08-24-2008, 07:33 PM   #12
Black_Soul
mine did the same thing you just hav eto tighted the two bolts that hold the window together
