Guide to most common 90-93 Honda Accord CEL diagnostics.
For information regarding about pulling the codes please refer to Aero's guide at this link.
http://www.cb7tuner.com/vbb/showthre...&highlight=CEL
ECU reset procedure: Reset the ECU by pulling off the negative battery terminal and removing the back-up fuse for 15 minutes. After the time frame has passed install back everything. Turn on the car and let it sit for 5 minutes and you're all set.
CODE 0 – (Electronic Control Unit) Faulty ECU
ECU – main purpose controls one or more electrical subsystems of a vehicle.
What to do: What you might want to do first before thinking of replacing it is check the electrical connections carefully. ECU is located under the passenger side kick panel. Pull out the carpet and the ECU will be revealed. With great luck the connections might be loose. If this exercise does not bring success , a replacement ECU will be your next move.
CODE 1 – Oxygen Sensor.
Oxygen Sensor – measure the proportion of oxygen.
What to do: Check your oxygen sensor. For F22A1 engines the Oxygen Sensor is located right into the upper part of the exhaust manifold. Remove the heat shield to fully reveal it's location. For F22A4/6 engines , the oxygen sensor is located right before the catalytic converter on the exhaust manifold down pipe.
To determine if the oxygen sensor really failed , turn on the car and let it idle & acquire a voltmeter. Disconnect the oxygen sensor connector and do this exercise. Increase the idle speed of the vehicle and check the voltage reading. The reading should be in between 0.5 volts to 1.0 volts. When you decrease the idle the voltage reading should be in between 0.0 to 0.4 volts. If the oxygen sensor fails within these exercise , replace it with and OEM replacement.
NOTE: NGK (NTK) & Denso are highly recommended replacement parts.
Oxygen Sensor replacement procedure: It's recommended that a special socket made for oxygen sensor to be used in order to ease the procedure. Unscrew the oxygen sensor and dispose of properly. Before installing the new oxygen sensor it is recommended to coat the threads with an anti-sieze compound to make future removal easier. Connect the oxygen sensor pigtails. Before running the vehicle it is recommended to reset the ECU.
CODE 3 & 5 – (MAP) Manifold Absolute Pressure.
Manifold Absolute Pressure – it is used by the ECU to control fuel delivery and ignition timing.
What to do: Check the hose that goes in to the MAP sensor. If there is deterioration or any signs of defects, it should be replaced. All electrical connectors regarding the MAP sensor should be check and see if they are connected properly. Failure of these exercise will result in replacement of the MAP sensor.
To replace the MAP sensor disconnect any electrical connections connecting to the MAP sensor. Remove the vacuum control box located on the passenger side firewall right next to the engine bay fuse box and remove the MAP sensor. Installation is reverse of removal. Before running the vehicle it is recommended to reset the ECU.
CODE 4 – Crank Angle Sensor.
Crank Angle Sensor – monitors the rotation of the crankshaft
What to do: Make sure the electrical connectors are on tight and properly connected. Make sure the position of the distributor is right that way it's supposed to be. If all else fails, replace the distributor and reset the ECU.
CODE 6 – Coolant Temperature.
Coolant Temperature – a resistor which sends signals in accordance with change in temperature.
What to do: Remove and replace the sensor with a new part. To remove the sensor , unlock the locking tab then unplug the green electrical connector located under the distributor and carefully unscrew the sensor. Be advised that coolant will leak out during this process and must install the new one ASAP. Before installing the new part , it is recommended to wrap the new sensor with Teflon tape to prevent leakage. Plug back the electrical connector and reset the ECU.
CODE 7 - Throttle Position Sensor (TPS).
Throttle Position Sensor – monitors the position of the throttle.
What to do: Replace the TPS. The TPS is located on the throttle body. Carefully unplug the electrical connector on the TPS and remove the TPS. Installation is reverse of the removal process. It's is recommended to reset the ECU as well.
Please refer Cokinut's guide to setting the TPS.
http://www.cb7tuner.com/vbb/showthread.php?t=16374
CODE 8 – Top Dead Center Position
Top Dead Center – Position of a piston farthest from the crankshaft. Position of a piston closest to the crankshaft is defined as bottom dead center.
