Alright so after receiving many PMs to share my "big 3" upgrade and other electrical upgrades. I'm going to attempt to put a DIY for this and hope that someone finds some use of it. PLEASE FORGIVE THE DIAGRAMS my computer MB died and I am using my laptop with shitty PAINT.
Let me start with some foreword, I bought my CB7 with my own money when I was 15 years old, aprox June 2000. I loved this damn car from the day I got it. I was OBSESSED with cars that go BOOM so I set out to upgrade the electrical system to feed my need.
First let me go through the GROUND SYSTEM.
We will be upgrading:
1. battery negative to CHASIS , I used 4 GAUGE WIRE
2. battery negative to engineblock/transmission ground, I used 0/1 GAUGE WIRE. BATTERY BOX will need to be removed to trace the factory ground, and replace with 0 gauge ground.
3. valve cover ground to alternator ground(I believe thats what this one is), I used 8 gauge wire
Seen here each number I listed matches to numbers in the diagram.
Now we will be talking POSITIVE WIRE UPGRADES
There are THREE wires we will be discussing
1. Positive wire from battery to FUSE BOX/ELD, I used 4 GAUGE WIRE (stock was 8 gauge)
2. Positive wire from battery through engine bay eventually leading to alternator, I LEFT THIS WIRE STOCK, I believe it is 2 or 4 gauge.
3. Positive wire DIRECTLY TO ALTERNATOR, I ADDED this wire myself, its an ADD-ON to make sure the alternator is getting enough juice to my battery. I used 8 GAUGE fused with a 60amp fuse rating(1/2 of my alternator's output). You MUST fuse this wire as its added directly to the alternator's positive stud.
I used cheapy gold plated autozone terminals, they came with 1 0gauge output, 2 4 gauge outputs, 2 8 gauge outputs.
I also took out my alternator, inspected it, had the brushings replaced and the alternator rewound for slightly higher output(stock alternator is 90 AMPS, mine was rewound to 120 AMPS). It cost me $61 at the time.
Finally, I upgraded to a really nice OPTIMA ORANGE TOP. They now call this battery the REDTOP REVERSED TERMINAL.
I did this upgrade in the winter of 2000. It is still running strong and charges at 14V all day long, and usually stays at 14.7-14.9. My amplifers capacitors VOLTAGE output reads 14.7 for those who asked.
Finally here is a picture unedited of the whole engine bay as seen above without the drawing on it so you can get the best look possible at the wires and where they connect/are routed.
Post questions as needed
If anyone needs better pictures, please let me know and be specific on what aspect you need a better picture of.
