This is a list of sizes for 90-93 replacement bulbs. It was compiled using a 1993 EX Sedan for reference, but 90-92 and coupes/wagons should be the same. If you have any changes or additions, please let me know.
Special thanks to scudweiser for the following information:
Code:
door courtesy lights: 3022 (also 3175) (10mm fuse-style)
dome light: 3022 (also 3175)
trunk light: 3022 (also 3175)
glove box: 3022 (also 3175)
cluster indicators: 74 (check engine light, battery light...)
cluster illumination: two 74 (overhead lights, so you can see needles)
gauge faces: three 194's (also 168) and two 74's
dashboard switches: tiny 12v twist-base peanut (OEM only, part number below)
climate control: medium 12v twist-base peanut (OEM only, part number below)
heat & fan knobs: 74
cigarette lighter ring: 74
ash tray: 74
ignition key hole ring: 74
auto shifter letters: 74
corners: 194 (also 168)
front running lights: 194 (also 168)
sidemarkers: 194 (also 168)
low beams: 9006 (H4 for JDM headlamps)
high beams: 9005 (H1 for JDM headlamps)
brake lights: 1157 (dual filament 1156-style)
front bumper blinkers: 3497 (1156 can be squeezed in)
rear blinkers: 1156
rear running lights: 194 (also 168)
reverse lights: 1156
high mount brake: 3497
license plate: 906 (also 921 and 194... has a 194-style base)
stock 90/91 fog lights: H3
stock 92/93 fog lights: H3-C (acura dealer-1st gen TL, or: 33165-SM4-003)
rear fog light: either 3497 or 1156 ?
visor mirror light: thin fuse style (OEM only, part number below)
spoiler brake light: red 5mm LED bar
the oem part numbers for the neo wedge bulbs are as follows:
39397-SA5-003 - climate control illumination
35851-SB2-003 - cruise control and sunroof illumination
35851-SM4-003 - hazard and defrost illumination (and probably fog)
35505-SM4-901 - dimmer knob illumination
35511-SM4-000 - defroster and foglight indicator bulb
34273-SA5-941 - sun visor mirror light
