** Note: This thread is for any non-F22ax NA engine build that satisfies the following requirements. Must have performance enhancing modifications to the cylinder head and/or block to be on this list. Full qualifies as both head and block modified, mild being only the head. **
Non-F22AX NA - FULL BUILDS:
Name
- Head:
- Camshaft:
- Intake:
- Exhaust:
- Stroke:
- Bore:
- Static Compression:
- Fuel Type:
- Engine Management:
F22AX NA - MILD BUILDS:
Name
- Head:
- Camshaft:
- Intake:
- Exhaust:
- Stroke:
- Bore:
- Fuel Type:
Name
Application:
Dyno Numbers:
- Block: Dyno Numbers:
- Head:
- Camshaft:
- Intake:
- Exhaust:
- Stroke:
- Bore:
- Fuel Type:
Name
Application:
Dyno Numbers:
- Head:
- Camshaft:
- Intake:
- Exhaust:
- Stroke:
- Bore:
- Fuel Type:
