Question: I swapped my F22A6 for an H22A Auto with LSD. How do you bypass the auto shift lock? I tried this from the Swap FAQ Thread:
"To make the shift lock operate properly you will need to run a wire from the shifter position switch to the tranny controller. On the left side of the shifter there is a box with about 5/6 wires going into it. This is the shifter position switch. You need to tap into the GRN/WHT wire and run it back to pin A7 on the TCM. Plug A is the bigger of the 2 plugs."
I tried this and it didn't work.
Any thoughts on how to make this work? I've read that other members could not get this to work as well. Maybe the FAQ was written wrong. HELP!
