[F23 long block
The differences between H23 head And Dohc F22b this will help in your build. choose the right head gasket, if your using a H series head gasket use a H series head it will line up better with no special mods. The same goes for the Dohc f22b.
When using a h23 head gasket with a h23 head this is what the ports look like you can use a f22 head gasket but you will have to do some mods. Some add Honda bond or hi-temp sealant at the bottom left port where its circled you will have to choose the right one some use f23 head gaskets.If using f23head gasket the only problem with that is you got to make sure the rivets are not in the way of the sealing.Make sure if your using a h22 head take the squirter out the back on top of the block so that you will get more oil to the head so that vtec will kick in.
On the f23's the head gasket fits the block but when the H23 head is on the f23 block the rivets are in the way of proper sealing causing it to leak you can remove the rivets and you would be fine.
If you choose to put a f22 head gasket on use the 90-93 the rivets are out side of the sealing of the head.
90-93 head gasket on h23 all ports match if you to choose to use your old head gasket make sure you spray cooper gasket spray if re-using gasket.
You got to change the driver side engine bracket so that you can put it in your 4th gen.
Make sure your if your using the h22 head use all the h22 timing parts, the teeth are different between the h23 that goes the same for the h23 use all timing parts for that head there timing sprocket its smaller than the accord one.
And for the final thing the water tube use the water tube for a 90-93 accord if your using a h23 head or dohc f22b head. If your using a h22 head you can use a water tube you can cut the tube in half and used a hoes and clamp to make the h22 head work.
Once you done all of that you can use the head bolts for the f series to tq down the head use the tq sequence for the head which is 29ftlb,51ftlb,72ftlb you can tq down a little more for boost applications 31ftlb,52ftlb,74ftlb to make sure head dont lift or get head studs.
Setting the timing once all that done then your good to go.
This thread was modified due to information that was missing.
All Info has been corrected
just wondering what is the point of a g23 build i never understood that does it have lower compression, more torque or more power? ive heard of them alot just never understood them
[/IMG]
