Here is a poorman's way of making Si-T bumper lights.
Disclaimer: I am not responsible for anything that you mess up. I am not responsible is you stabb/burn/harm yourself in any way when attempting this modification.
Parts Needed:
92-93 Clear bumper lenses (ebay,etc.)
90-91 OEM bumper lenses
A tube of RTV in the color of your choice (I used Clear)
Tools Required:
Small screwdrivers
Pick (Optional)
Hammer (Optional)
Oven
Cookie sheet
Oven Mitts
Step 1: Seperate the lense(NO PICTURES)
Take your 90-91 bumper lenses and remove the amber reflector. You can bake the lights if you want. Mine had broken tabs, so i used and hammer and hit around the sealed area to break the lenses apart.
Step 2: Remove the amber reflector
Once apart, you can continue breaking the light or pull outward on the lense sides and pull the amber reflector out. ( it is held in by two tabs on opposite corners)
Once removed you will have this:
Step 3: Baking the Clear lenses
Preheat the oven to 200*. Place the lenses on a cookie sheet that is layered with oven mitts (this is to prevent melting).
Place the lenses in the oven for atleast 5 minutes. I just kept check every couple of minutes to make sure melting did not occur.
Once they are hot enough to seperate, Use the pick tool or screwdriver to help get a gap to pry with. Be EXTREMELY careful when prying. Most notably when you come to the curved area.
Once apart, They will look like this.
<The G-Man.
Step 4: Inserting the Amber corner.
You will notice that reflector is slightly larger than the lense. you can dremel this down to make a nicer fit, I just pushed mine down in. It bulged a bit, but the silicon takes care of that.
Step 5: Seal and let sit
Once done, put a bead of silicon around the clear part of the lense. Press them together and either tape them together or bear hug them. Once a bond has been made, let them sit over night and check for any more openings in the morning. Add additional silicon if needed.
Last, Enjoy your new ricer front end
Parts Needed:
Tools Required:
Small screwdrivers
Pick (Optional)
Hammer (Optional)
Oven
Cookie sheet
Oven Mitts
<The G-Man.Step 4: Inserting the Amber corner.
shipping kills me...
