Go Back   CB7Tuner Forums > Parts & Performance > Suspension > Brake Performance
Old 10-15-2003, 02:02 PM   #1
Rage237
Rage237 is cool... so far.
rotor over hub conversion
ok i just read the thread above about the "best breaks for a 4th gen)
now my question is,
is all i need to do this are
99 CL 2.3 hubs
99 CL 2.3 rotors
i can keep my stock calipers and my stock spindls correct
i will just need to press out my stock hub and rotor and then press in the CL hub bolt it up and then install the CL rotor and then stick my caliper back on
is this all correct?
Robert Sartore
Kustom Audio Werx
1991 Honda Accord EX Sedan (FOR SALE)
Kaminari rear-sides/Blackwidow front/(I/H/E)/jdm head lights/red-clear tails/+more to come
Rage237 is offline   Reply With Quote
Old 10-22-2003, 09:35 AM   #2
wesselerp
wesselerp is cool... so far.
Send a message via AIM to wesselerp
I've heard alot about this swap and even have all the parts for it at home. But i've never seen any pictures of it completed. I have heard from people that they have the swap, but i'm a sceptic. When i have mine complete, i'll have plenty of pictures. For the rotor over hub swap, the typical set up is as follows...
99 2.3CL hubs
93-96 vtec lude rotors
90-93 Accord wheel bearing (replace or use the currect bearings)
93-96 vtec lude calipers OR legend dual piston calipers (93-95 coupe, 93-95 GS Sedan)
Brake pads for the caliper used.
wesselerp is offline   Reply With Quote
Old 10-22-2003, 03:16 PM   #3
HondaFan81
Honda Enthusiast
HondaFan81 seems to have made some friends! HondaFan81 seems to have made some friends!
if you read this article by USC, you'll realize the legend calipers is a bad idea
http://www.cb7tuner.com/vbb/showthre...=&threadid=836
1) But could you tell me more about using the Prelude calipers? Do these work fine and keep the bleeder screw on top or work the way is should?
2) Also, are the 99 CL rotors & the Prelude rotors the same size? I think the CL's are 10.2" which are same as our stock Accords I believe...are the Preludes bigger?
3) Also, I would think depending on what size rotors you get...do the caliper brackets need to be replaced? and with what?
HondaFan81 is offline   Reply With Quote
Old 10-22-2003, 03:27 PM   #4
Rage237
from what i have heard is that if you use the CL rotor you can keep the accord caliper (thats my plan)
Robert Sartore
Kustom Audio Werx
Old 10-26-2003, 07:51 PM   #5
HondaFan81
Honda Enthusiast
99 2.3CL hubs
Brake pads for the caliper used. [/b]
1) Do the VTEC prelude calipers properly install & fit on our Accords? No upside down installations of it, like w/Legend calipers?
2) Do these prelude calipers need the prelude caliper brackets as well? Or are the Accord ones the same?
Old 10-26-2003, 08:37 PM   #6
aero
Moderator
aero is cool... so far.
yes, the lude si calipers will fit. and yes you will need the brackets that go w/the caliper.
aero is offline   Reply With Quote
Old 10-26-2003, 09:44 PM   #7
HondaFan81
Honda Enthusiast
ok about the calipers...but do the Lude calipers install properly? No inverted shit like with the Legend caliper setup?
If anyone read USC's article on how they mount & how it doesn't work properly, you know what I'm referring to.
Old 10-26-2003, 09:54 PM   #8
HondaFan81
Honda Enthusiast
Rear disc Conversion questions....
Can some peeps answer the questions in red for me in detail on what I need & from where to do it all up. Thanks.
90 Accord EX Rotor-over-Hub Conversion Rear brakes:
1) Rear Susp. Conversion (trailing arms, sway bar, steering knuckles)
2) What upper & lower control arms?
3) 99 > 2.3 CL hubs
4) New stock Accord wheel brgs
5) What rotors & size?
6) What calipers & brackets?
7) SS lines
Miscellaneous Brake system upgrades:
8) 90-93 > Integra w/4 whl disc proportioning valve
9) BMC change?
10) Brake booster change?
Old 12-18-2004, 07:04 PM   #9
olivrooom
Location: *socal* (damn... moved back from Newport Beach)
olivrooom is cool... so far.
From my experience, I did my rear disc swap and didn't have to do the rotor over hub conversion. It was already like that! Woohoo!
O'skool fo sho! You might hate, but I been doin' this long before you know.
olivrooom is offline   Reply With Quote
Old 12-18-2004, 09:15 PM   #10
owequitit
owequitit is very helpful owequitit is very helpful owequitit is very helpful
Send a message via AIM to owequitit
All Prelude VTEC rotors (including 97-01) are 11.2" vs. the 10.2" for stock CB7 front rotors.
I am not sure about the SI rotors, but I am pretty sure the base model 92-96 Ludes also have 10.2" inch rotors.
The Prelude calipers should bolt right up to the Accord knuckle and work perfectly as long as you have the correct mounting bracket, which is the 23T. Just about every Honda front brake caliper I have ever seen is almost identical, in that they are single piston,and mounted on the front of the brake assembly. This would put the bleeder bolt right where it needs to be, and eliminates all concern about proper piston sequence on multi-piston calipers. Make sure you use the correct rotors for your application, because the thickness does vary.
The 90-93 Accord wagon has larger brakes also, but you may want to ask 2point6 about that, I am pretty sure he has done it.
owequitit is offline   Reply With Quote
Old 12-19-2004, 02:06 AM   #11
arrozburner
arrozburner is cool... so far.
Send a message via AIM to arrozburner Send a message via Yahoo to arrozburner
i did the rotor over hub with prelude rotors and calipers and i used the whole knuckle off of a cl...easier to swap over rather than removing the hubs...heres a pic of the job finished
http://www.cb7tuner.com/vbb/showthre...er+1992+accord
Originally Posted by fizzbob7
Originally Posted by ACC0RD22
So. Cal OUTLAWZ
arrozburner is offline   Reply With Quote
