Go Back   CB7Tuner Forums > 4th Gen-eral > Racing > Auto-X / Road Racing
Old 04-28-2009, 08:34 PM   #1
The G-Man
The G-Man seems to have made some friends!
Send a message via AIM to The G-Man
Lets talk spring rates
As it sits, it looks as if I am pretty much destined for 3rd place in ST in my region this year.
Neuspeed Race springs and KYB AGX isn't cutting it. I need something with custom spring rates.
I was thinking 30% stiffer in the rear would be a good place to start, and something fairly soft in the front, but yet stiff at the same time.
So at this time lets say 600 in/lbs front and 780 in/lbs in rear.
Once I get these rates figured out, then I will have a shock custom valved to best match the rates, and extended top hats fabricated to still allow proper travel in the front.
Gary A.K.A. Carter
The G-Man is offline   Reply With Quote
Old 04-28-2009, 08:41 PM   #2
d112crzy
Banned
d112crzy seems to have made some friends!
God damn, that shit is stiff! Do you plan on making your car a track car only once you get your suspension? It sure as fuck won't be a comfortable ride with those rates.
What are the Nuespeed Race rates? I was thinking of doing 550 rears with 400 fronts on mine with custom valved bilsteins. As well as some removable limiters on the front.
Can you add a solid rear strut bar without moving you up a class? I think with some STIFF ass bars, you won't need such high spring rates.
d112crzy is offline   Reply With Quote
Old 04-28-2009, 08:57 PM   #3
dohcb7
dohcb7 is cool... so far.
why dont u just get coilovers? they are better than lowering springs in my opinion
Upgrade your mind before you upgrade your car
"So. Cal OUTLAWZ "
dohcb7 is offline   Reply With Quote
Old 04-28-2009, 09:01 PM   #4
Flatline
Flatline seems to have made some friends!
because he needs custom spring rates.
Flatline is offline   Reply With Quote
Old 04-28-2009, 09:04 PM   #5
mcdizzle
mcdizzle is cool... so far.
Send a message via AIM to mcdizzle
because good ones (not f2, d2, tein, ksport) cost a lot of money.
custom valved bilsteins/konis matched with a good high spring rate lowering spring or ground control setup will be the best bet.
My Members Ride Thread
Originally Posted by deevergote
You have to think outside the box to get IN the box!
mcdizzle is offline   Reply With Quote
Old 04-28-2009, 09:17 PM   #6
The G-Man
I can add, and will add a solid rear bar. But it can only tie the two strut mounts together. A friend of mine is going to help me fabricate solid front and rear bars.
Honestly, I wasn't sure where to start with rates for this car because there just isn't a whole lot of information out there from people auto crossing theirs. And for the foreseeable future, this is my only car.
And as for the Neuspeed rates, I can't really find any good info for them. But they are progressive as noted by the uneven coil spacing.
I am getting coil-over sleeves, from Ground Control. These sleeves use standard 2.5''? inner diameter springs, and are available in pretty much any spring rate you want.
But really, I will set my ride height once, and then corner-balance it. There is absolutely no need to adjust ride height often.
Gary A.K.A. Carter
Old 04-28-2009, 10:01 PM   #7
Charliehstle209
Charliehstle209 is cool... so far.
Send a message via AIM to Charliehstle209
i was just researching my NexSS coilovers spring rate and cant find nothing other than,
"High Molecule Force Coil Springs - The coil springs in the NEX suspension is made from high molecule forced steel. After being tested by millions of times on our dyno, we found this spring construction to resist wear and tear, and sustain its efficiency and consistent spring rate. The handling and performance can match by the skill of each driver due to the high spring rate used in the NEX suspension"
No numbers...
when i had it aligned with a decent drop, it was very responsive and pretty stiff. During autox racing, it feels pretty solid. im afraid to go any lower...
i cant wait till i get this progress bar, upper and rear struts installed...
93 Coupe........AutoX
Charliehstle209 is offline   Reply With Quote
Old 04-29-2009, 03:23 AM   #8
mcdizzle
i used to run 400f/300r on my car when i had koni/gcs. it was a good set up and i never stiffened the konis. but i DD'd the car as well. if i went back to GC's id prolly go somewhere like 550f/500r with specially valved konis to match them. stiff enough for racing but still bearable for street use as well.
Old 04-29-2009, 08:38 AM   #9
The G-Man
Why softer out back?
Gary A.K.A. Carter
Old 04-29-2009, 10:24 AM   #10
TheNextEpisode
TheNextEpisode is cool... so far.
Send a message via AIM to TheNextEpisode
x2
TheNextEpisode is offline   Reply With Quote
Old 04-29-2009, 10:55 AM   #11
d112crzy
Banned
Because most of the weight on our cars is in the front and thats where we get a lot of our body roll from(sloppy front end). You usually only want stiffer rears to prevent squatting in drag racing situations.
Old 04-29-2009, 12:38 PM   #12
The G-Man
True, but you also want to prevent squatting in a road racing situation as well.
Gary A.K.A. Carter
Old 04-29-2009, 01:14 PM   #13
mcdizzle
well i go softer out back because thats what ive always read was recommended. a good anti-sway bar/solid tower brace bar like an esp will help out greatly in the rear as well. id prolly go even all around at 550f/r but im not 100% positive.
im probably just going to be getting a neuspeed super cup kit on my car and calling it quits for suspension, as id rather have a better starting point for road racing (s2000 or c5 corvette).
Old 04-29-2009, 07:03 PM   #14
93F22A6
93F22A6 is cool... so far.
Send a message via AIM to 93F22A6
That sounds extremly stiff for a CB. Hell the race car I work on has 350+ in the front and 400+ in the rear. It's circle track car but still, it 3150 pounds a little bit heavier than a CB but of corse a completely different car. I would scale the car first and go from there.
86 4Runner - 22RE 5spd, 4" Lift, 35x12.5R15 BFG Km2's, 4.10 gears
"The Turtle"
DD/Trail Rig/Mud Bug
93F22A6 is offline   Reply With Quote
Old 04-29-2009, 07:29 PM   #15
mcdizzle
weight of the car really doesnt mean a whole lot when it comes to the spring rates, a guy locally had a miata that was running 600lb f/r on it for autocross. the thing road like it was on fence posts but it handle like it was on rails so yah.
Old 04-29-2009, 07:39 PM   #16
93F22A6
If your trying to get the perfect 50/50 weight distribution uh yes it does. Scaling the car tells you how much weight is on each tire.
"The Turtle"
Old 04-29-2009, 07:49 PM   #17
mcdizzle
oooh ok, now i see what your saying. i thought you were refering to just getting an overall weight of the car.
isnt this what corner balancing is for? also that is kinda why i ran lower rates in the rear of my car.
Old 04-29-2009, 07:57 PM   #18
93F22A6
Corner balancing? Can you explain this to me, not sure what it is. True lower spring rates in the rear will put more weight to the rear of the car, to low and you'll prob sag and and poor handling.
"The Turtle"
Old 04-29-2009, 08:03 PM   #19
mcdizzle
i cant describe it, but i think this website does a good job
http://www.nsxprime.com/FAQ/Performa...nerbalance.htm
Old 04-29-2009, 08:11 PM   #20
93F22A6
I just breifly skimed it but thats basically what I was saying. Or at least same goals. Except in circle track we have a different weight distrubution, can't remember what it is though. I know I hate having to go and put rounds in and out of the car though, get time concuming. Espcially when reggie, our driver, and my shop teacher change their minds . If you want to know how to set up a car go find some of the old guys who have been racing for a while and just listen. I've learned alot over just the past few months.
"The Turtle"
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
