Go Back   CB7Tuner Forums > Site Features > DIYs > Welding and Fabrication
Old 05-29-2009, 02:15 AM   #1
TypeG
Moderator
TypeG is very helpful TypeG is very helpful
anyone ever tried Durafix Aluminum Welding Rods?
just wondering if they're as good as the video says they are.
later.
Avoiding dirt at all costs
TypeG is offline   Reply With Quote
Old 05-29-2009, 02:21 AM   #2
casterX
casterX is cool... so far.
wow! vid was quite convincing..
casterX is offline   Reply With Quote
Old 05-29-2009, 02:35 AM   #3
TypeG
Moderator
yeah, they made it look easy. i don't know if these are new or not, but it's the first time i've heard of them. later.
Old 05-29-2009, 03:29 PM   #4
C91BLX7
C91BLX7 is very helpful C91BLX7 is very helpful C91BLX7 is very helpful
Thats not welding.... pish. Solder.
wat?
C91BLX7 is offline   Reply With Quote
Old 05-29-2009, 05:31 PM   #5
TypeG
Moderator
more like brazing, which is a form of welding. later.
Old 05-29-2009, 05:33 PM   #6
C91BLX7
yeah I guess, I wouldn't trust it for something real important. I don't see the metals actually fusing together, rather just laying on top.
wat?
Old 05-29-2009, 05:39 PM   #7
d112crzy
d112crzy seems to have made some friends!
Yeah, there's no real penetration going on there. It's more like a badass glue. I wouldn't trust this if you're using it in a high heat or anything that will support a lot of weight/tension.
It will work great with brazing though.
d112crzy is offline   Reply With Quote
Old 05-29-2009, 05:42 PM   #8
TypeG
Moderator
yeah, i was going to use them to fill holes. later.
Old 05-29-2009, 05:47 PM   #9
d112crzy
I usually use my penis for that.
Old 06-17-2009, 07:16 PM   #10
sleepygreen
sleepygreen is cool... so far.
LMAO would this work for shaving the side mouldings?
clicky the siggy!!!
ARCADIA GREEN MEMBER #20
AIM=SleepygreenCB7
Yahoo=annamaineeak@yahoo.com
sleepygreen is offline   Reply With Quote
Old 06-17-2009, 09:40 PM   #11
TypeG
Moderator
no, not at all. the door skin is made of mild steel. later.
Old 06-17-2009, 09:46 PM   #12
mndude07
mndude07 seems to have made some friends!
Send a message via AIM to mndude07
Like welding, a brazed joint, if done properly is stronger than the surrounding metal by a significant margin. So depending on the application, its plenty strong.
There are no black and white suspension answers!!!!!!!!!!!
mndude07 is offline   Reply With Quote
Old 06-17-2009, 11:20 PM   #13
bcjammerx
bcjammerx seems to have made some friends!
Send a message via AIM to bcjammerx Send a message via Yahoo to bcjammerx
depends, how sharp is your penis?
____
bcjammerx is offline   Reply With Quote
Old 06-17-2009, 11:36 PM   #14
H22A91CB7
Banned
H22A91CB7 may be a total jerk. It is very likely.
something like if your doing the h-swap and wanna keep the h powersteering
H22A91CB7 is offline   Reply With Quote
Old 06-18-2009, 12:11 AM   #15
mj213
mj213 is cool... so far.
Send a message via AIM to mj213
I don't think anybody needs any buttholes filled any time soon, but thanks for the heads up.
mj213 is offline   Reply With Quote
Old 07-22-2009, 03:54 PM   #16
rexload
rexload seems to have made some friends!
I was just going to make a thread about this.... lol
I've tried welding aluminum but failed because I obvioulsy don't have the proper equipment but they make it look really easy in the vid.
So I am seriously thinking about getting their rods to do the following
1.connect my intercooler piping this way and ditch all my couplers
2.make an aluminum exhaust from resonator-back (for weight saving reasons)
Will it hold up?
rexload is offline   Reply With Quote
Old 07-22-2009, 04:27 PM   #17
kamaccord
kamaccord is cool... so far.
later.
This is an awesome thread. Has anyone priced the aluminum welding rods? this was very informative. Thanks.
600HP" 1990 ACCORD LX COUPE COMING SOON
CLICK HERE TO VIEW MY 1990 CB7
kamaccord is offline   Reply With Quote
Old 07-29-2009, 09:06 AM   #18
lowandslow
lowandslow is cool... so far.
welding aluminum isnt as easy as you would think. im certified mig,tig,and arc. alot of stuff you tig weld is just brazed. like tig welding copper
lowandslow is offline   Reply With Quote
Old 08-02-2009, 08:12 PM   #19
SEXXIILADY712
SEXXIILADY712 is cool... so far.
Send a message via MSN to SEXXIILADY712
http://durafix.com/#order
SEXXIILADY712 is offline   Reply With Quote
Old 08-29-2009, 06:10 PM   #20
rexload
I got the rods and tried this on intercooler piping just 30 minutes ago.
It is not as easy as it looks in that video. Actually it didn't work at all for intercooler piping. I sat there heating one spot for 30 minutes and it didnt get hot enough to melt the rod on it like it is shown in that video.
Maybe this requires some rediculously powerful torch?
