Ok...so i've decided to build a H22 and boost it. I plan on having it fininshed by the end of the summer. I hope to make 400whp on low boost. Here is a list of all the parts that I plan on getting for the build or already have
Head
SuperTech Valve Springs
SuperTech Valves
SuperTech Retainers
Block
Laskey Built
Benson sleeved block
Benson balanced and micropolished crank
CP pistons and rings
Pauter rods
ACL bearings
Balance shafts removed
OEM oil pump
Misc Parts
H23 Manual Tensioner-Have
ARP Head Bolts-Have
New Timing Belt-Have
New Water Pump-Have
Hondata S300
How much power do you think this build can/will produce? The turbo that i plan on getting is a Garrett GT30R. If anyone can think of anything else that would benefit my build then please let me kno.
Head
SuperTech Valves
SuperTech Retainers
Block
Laskey Built
Pauter rods
ACL bearings
OEM oil pump
Misc Parts
ARP Head Bolts-Have
New Water Pump-Have
Hondata S300
I need a custom turbo manifold built....
