H23 head on F22 block?
    What exactly are the requirements to install an H23 head on an F22Ax block? Ive heard that some coolant passage needs to be blocked off (not sure where though), but would the F22 crank and pistons be used or H23 parts? I'd assume either would work (not sure about any clearance differences), but I'd enjoy some input from someone with experience in swaps to guide me.
    Search links would be fine too, I checked around but I'm bad with keywords.
    Thanks in advance!
    MRT(vvv) --Stock CB7 Enthusiast #1--
    Vouches: new_beginnings, ThrakBarts, beanzfynest617, JaK FRoSTWhiTE, 92_EX_Ninja, mak
    i am with the dumb. i cannot brain.
    http://hondaswap.com/engine-building...22-hybrid-142/
    http://www.honda-tech.com/showthread.php?t=776837
    http://www.superhonda.com/forum/f13/h22-head-f22-52293/
    http://www.jdmuniverse.com/forums/ho...f22-block.html
    and it will be known as the G22 or G23 FYI
    also keep us up to date with this i would love to do it i have my f22a1 block and another h22 head layin around thanks
      im pretty sure a GSR timing belt is used
      to achieve a Fuck, you must first give a Fuck
      Follow me on twitter @tru_whitetrash
        Those links were EXTREMELY helpful, thanks a lot! Any other input would be great too, if somebody else here has done this swap.
        Also, I'm assuming factory engine management (P14) would be sufficient if I keep the same bore/stroke? Thanks again for any help.
        EDIT: Some of those links were for H22 heads and not H23, but I followed some more links within to find more H23 info.
          glad i could help i will be doing a f22 block h22 or 23 head frank engine for a backup motor... so let me know how she goes.
            Originally posted by veyvey View Post
            let us know how she goes.
            X2!!! I just got a H23 head with skunk2 cams
            South Texas M_thaf_cka, that's where I stay!
            Check out my Frost White CB
            http://www.cb7tuner.com/vbb/showthre...ight=SpdJnky93
              any news? i just found metal in my oil pan a nice nickel sized chunk...... so out goes the h22 for inspection....how goes your motor>?
                f23 headgasket.
                I <3 G60.
                  Originally posted by wed3k View Post
                  f23 headgasket.
                  why the f23 gasket??? sorry im getting parts for this as i go but im doing a f22a6 or 4 block with h23 head.
                  Members Ride sold...
                  I'm back...... with a coupe. oh boy here we go.
                    its the best gasket that fits the ports/passages of both the block and head.
                    if you need parts i have an h23 timing gear.
                    Originally posted by d112crzy
                    So you're throwing a bitch fit because some other girl at school has the same nail polish and skirt as you do?
                      i need the parts to finish the head out.... its the parts that hold the cams in place...and then a vavle cover lol.
                        you mean you doint have the cam caps? those are supposed to be paired with the head. if you use another set and those are off, the cam may not spin.
                        I <3 G60.
                          so its not sumthing i could order from majistic honda???
                            You can, but then you'll have to get the cam bores align honed and you'll more than likely have to get some bearings for them.
                            More work than it's worth. You're not gonna get much power from the h23 head, honestly.
                              Hater.. lol
                              Praise The Lowered...
