how to pull codes????
    im trying to figure how to pull the codes from my accord. any suggestions or help.????
    For we were saved in this hope, but hope is that is seen is not hope;
    for why does one still hope for what he sees? ROMANS 8:24
    Yeah I role a Honda, yup on 1 Accord with the Lord!!!
    http://www.cb7tuner.com/vbb/showthre...t=Diagnose+CEL
      pull the passenger floor area carpet down & you can see the ECU cover plate. there is a hole in it where you can see a LED. Turn the key to ON & the light will blink your code (if any present).
      Officially "hilarious mad sarcastic"! Thanks CB74christ for the recognition of my work.
        For those that dont have the LED light, and I dont, there is a plug on the pass side in the kick panel. I hooked a jumper wire in there and pulled codes from my check engine light.
        KDI CUSTOMS-AUTOMOTIVE UPHOLSTERY www.kdicustoms.com
          The LED is only on the 1990 models, I believe.
          The link that MyDianaZ06 posted is the most thorough walkthrough there is on this site. If you can't figure it out by that link... take your car to a shop.
            yeah i found it now the hard part is pulling them.... yeah and i agree the easiest way is to go to that show thread he posted !!! thank u CB7TUNERS!!!!
              Pulling them is not hard.
              Find plug
              Insert paperclip
              Turn key
              Count flashes
                also a nice write up on this on my site thats in my signature. just go to reference material!
                Dave Estes (owner of) DB Customs & Automotive Repair
                http://www.automotivecustomworld.com
                Just check it out!!
                free people search http://www.dbcustoms.ws
                  Pulled The Code!!!
                  so i found the plug and did as the forum walkthrough told me to do. if i am correct i two long blinks and one short blink equals twenty one,(correct me if im wrong). so 21=VTEC spool solenoid valve... I do not have the vtec hooked. i was told that if the vtec is not hooked up the ecu will reset itself the 3rd time that it starts or whatever???? HELP ME OUT?
