Ok. My tach hand was dropping to zero during high speeds in my 90 LX and I determined that it was either the ignitor, coil, or distributor. So, instead of using trial and error, I purchased a new distributor and an aftermarket coil. Now, the original distributor was internal coil. The new one is for external coil applications. I was having trouble starting my car after replacing the parts and i thought that the timing was off. I put the old distributor back on and it started right up. I did some research and I found out that I have to wire up the coil.
I've only been able to find info on converting from an internal coil to an external coil using the old distributor. I need to know how to wire up the AEM external coil to my new external coil distributor.
