D4 blinks , S blinks what am I going to do?
The solution is , go outside dressed in a pink tutu and impress the hell out of everybody.
Easy to diagnose the codes. It's very similar from pulling the ECU codes , except that either the D4 or S will blink.
For 90/91 equipped with the "S" , the S will blink.
For 92/93 the D4 will blink.
CODES:
1: Faulty , Disconnected or shorted lock-up solenoid A
2: Faulty , Disconnected or shorted lock-up solenoid B
3: Disconnected throttle angle sensor
4: Speed Sensor
5: Console switch
6: Off Console switch
7: Shift Solenoid A
8: Shift Solenoid B
9: NC Speed Sensor
10: Water Temperature Sensor
11: Ignition Coil
14: FAS Wire , PGMFI
15: NM Speed Sensor
CODES:
4: Speed Sensor
5: Console switch
7: Shift Solenoid A
8: Shift Solenoid B
9: NC Speed Sensor
11: Ignition Coil
15: NM Speed Sensor
Originally posted by TECHAUTO
