Old 10-21-2009, 10:46 PM   #1
Oja
Oja may have said something they shouldn't have...
rubber grommet stuck on spark plug
I noticed when I installed new spark plug wires. The rubber boot thing on the end of the O.E.M. spark plug wire connector, came off around the installed spark plug my new boot isnt fitting all the way correctly connected too plug its running fine but i think it might just be arcing to the plug. And i have tried getting something down there to grab it and a spark plug socket wont fit b/c of the rubber grommet in the way err pain in my butt. WHAT SHOULD I DO
I want to die in my sleep like my grandfather... Not screaming and yelling like the passengers in his car
My Ride *****;http://viewmorepics.myspace.com/inde...lbumId=2844229*****
Oja Thnx Everyone, at cb7tuner.com
Oja is offline   Reply With Quote
Old 10-21-2009, 10:54 PM   #2
MR.PHIL
Contributing Member / AoM December 2007
MR.PHIL is cool... so far.
get you a straight hook and remove it
[IMG]http://www.toolstw.com/upfiles/shop/****/4a81134ec48fc.jpg[/IMG]
-->751 whp @ 27psi <--...Midnight Tuning <----
MR.PHIL is offline   Reply With Quote
Old 10-21-2009, 10:57 PM   #3
gcvphoto
Banned
gcvphoto is cool... so far.
^^^^ also, make sure not to let any of the rubber to fall in without the spark plug still in.
gcvphoto is offline   Reply With Quote
Old 10-21-2009, 11:10 PM   #4
xaaronx
xaaronx is cool... so far.
Send a message via AIM to xaaronx
question, what wires were they? my brother had my car before me and he always took the cheap route. he had some autozone spark plug wires and every one of them fell apart when i went to change them and the spark plugs. i replaced them with NGK's and will never buy anything of lesser quality.
when that happened to me, i used needle nose plyers to grab the parts that fell apart and/or stuck to the spark plug. good luck
90 ACCORD EX..<-- MR thread
xaaronx is offline   Reply With Quote
Old 10-21-2009, 11:28 PM   #5
Oja
::question, what wires were they?
Old 10-21-2009, 11:32 PM   #6
Brandoncb7
Brandoncb7 seems to have made some friends!
Send a message via AIM to Brandoncb7
I had my actual spark plug break off inside the tube. I've also had what you're talking about happen and I ended up using a flathead screwdriver and some long ass forceps to pull it out. It took forever but it eventually came out. It's just one of those pain in the ass things. The forceps are the only thing i've used though.
Brandoncb7 is offline   Reply With Quote
Old 10-21-2009, 11:33 PM   #7
xaaronx
i can't really remember. they were gray in color and had the word 'smart' in the name i believe. just try not to get those anymore if that's what you have. the NGK's can be purchased for like 30 bucks and they're WELL worth it.
i bought mine from this guy because most places around wanted like 40-50. http://www.ecrater.com/product.php?pid=2147235 he had them shipped pretty quick, too.
Old 10-22-2009, 01:15 AM   #8
wed3k
wed3k seems to have made some friends! wed3k seems to have made some friends!
Send a message via AIM to wed3k
i took the valve cover off and used a regular needle nose pliers on it.
I <3 G60.
wed3k is offline   Reply With Quote
