I really don't understand why people have trouble with getting air into their coolant systems. I've never had this problem and I follow this procedure:
- Close radiator drain plug.
- Open bleeder valve.
- Fill coolant to lower radiator neck.
- Start engine, let coolant temp get to normal operating temp.
- Top off coolant in radiator to lower radiator neck.
- Shut engine off and put radiator cap back on.
- The waiting for fans to come on twice takes far too long, not necessary.
You will never have problems with air in system or low level following this procedure, unless you have other unforeseen coolant system problems.
