i click the button trying to turn it off and it stays on all the time. a little help please.
Why does my "S" light stay on?
same way u pull the codes from the cel.jump the od1 with a paper clip and ur s light will blink.Originally posted by 809king View Posthow do you pull the codes and where is the tcu located?
i have the same problem, i tried pulling codes, the "s" light didnt give me any codes.it just stayed lit up. the only code i could pull was a o2 sensor. any ideas?" the only thing that stands between a Marine and God, is a Corpsman "
"Don't shoot your mouth off unless your brains are loaded"
i forgot to add, it goes off if i down shift to d3, then cuts back on when shifted up. is there anyway to test a tcu, if i was to go to the jy to buy one? are all 9093 auto tcu's the same? do the different submodels have anything different?thanksLast edited by hmchaos; 07-18-2010, 09:05 PM." the only thing that stands between a Marine and God, is a Corpsman "
I know....I'm gunna lower it
