Go Back   CB7Tuner Forums > Beginner forum -- New members post here! > Beginner Appearance
Old 11-12-2009, 08:21 PM   #1
lucifer1
lucifer1 seems to have made some friends! lucifer1 seems to have made some friends!
MDX steering wheel
I bought a Prelude steering wheel after reading a few threads on here. After trying to install it, I started measuring and came to the conclusion it does not fit. It sits almost an 1" too far inward and the plastic trim prevents it from being tightened. I could make a spacer but then there would be hardly any spline left and unsafe. To install it properly, the spline needs to cut off and replaced with the longer one off the accord wheel.
the prelude plastic trim sits nearly flush vs the accord which makes over .5" of plastic that is in the way of bolting the wheel on..
Since modifying the prelude wheel defeats the whole purpose of buying it and I still wanted a different steering wheel, I decided to install a nice leather MDX steering that I had laying around(Yes I know this is a '90 and it did not come with airbags and the airbag will not be functional). It sits too far out and has the newer larger spline. After a few measurements, I cut the original MDX spline off and replaced it with the shorter and smaller one of the prelude
wheel.
An idea of how much of a difference ther is betwween the MDX and accord steering wheels
The original MDX spline
I used a cut off wheel to cut the weld, then took a hammer to knock the spline off. The I ground the weld smooth with flap disc
Mocking the spline up, it will be about .25" out further than the accord wheel
Prelude spine welded up front and rear.
Almost identical, basically just the difference in thickness of leather vs plastic
The rear trim mount points and spoke ends were ground down to make more wheel to column trim clearance
The newer columns use a bolt instead of a nut/stud combo. The accord column leaves very little space between column and rear of airbag. I had to cut the bracket to clear.
wired up to the accord slip ring
All finished
lucifer1 is offline   Reply With Quote
Old 11-12-2009, 08:25 PM   #2
ikayto
ikayto seems to have made some friends!
Send a message via AIM to ikayto
WOW, I am very impressed with the craftsmanship and those welds. Good job in getting it to work, I'm sure now no wheel cannot be made to fit now.
cant wait to see what other ingenious things you come up with
ikayto is offline   Reply With Quote
Old 11-12-2009, 08:32 PM   #3
F20A CB7
+1 rep for u!
Old 11-12-2009, 08:33 PM   #4
brsteinbach
brsteinbach seems to have made some friends! brsteinbach seems to have made some friends!
Very nice job bro.
Looks great!
Click picture for MRT
Sparkin CB7
brsteinbach is offline   Reply With Quote
Old 11-12-2009, 08:33 PM   #5
Hondateck2010
Hondateck2010 is cool... so far.
Send a message via AIM to Hondateck2010 Send a message via MSN to Hondateck2010 Send a message via Yahoo to Hondateck2010 Send a message via Skype™ to Hondateck2010
100 points since I wanted to do this but with a 03-07 accord streeing wheel
Links to my rides :
1992 Accord EX*
1990 Accord EX
1991 Accord SE (4th)
1991 Accord SE (3rd)
1991 Accord SE (2ND)
1991 Accord SE
Hondateck2010 is offline   Reply With Quote
Old 11-12-2009, 10:08 PM   #6
kouzie
kouzie is cool... so far.
Something new everyday!!!
kouzie is offline   Reply With Quote
Old 11-12-2009, 10:11 PM   #7
SacTownCb7
SacTownCb7 may have said something they shouldn't have...
Send a message via AIM to SacTownCb7 Send a message via MSN to SacTownCb7
dude that looks freaken sweet.
good job
SacTownCb7 is offline   Reply With Quote
Old 11-12-2009, 10:14 PM   #8
Ont1992ADL
Ont1992ADL is cool... so far.
Thats flippin amazing should be moved to the Stickys on the DIY side! Nice job! Rep Points for you sir! Whats that green CB in the backround? is that yours?
Ont1992ADL is offline   Reply With Quote
Old 11-12-2009, 10:16 PM   #9
Joshy
Joshy seems to have made some friends!
Send a message via AIM to Joshy
Excellent work!
My pictures/photos will return soon...
Joshy is offline   Reply With Quote
Old 11-12-2009, 10:39 PM   #10
wherm
wherm seems to have made some friends!
Send a message via AIM to wherm Send a message via Yahoo to wherm
nice work, great welding!
wherm is offline   Reply With Quote
Old 11-12-2009, 11:03 PM   #11
Tippey764
Silver Member
Does the airbag and cruise control switches still work?
Tippey764 is offline   Reply With Quote
Old 11-12-2009, 11:06 PM   #12
vietkid_2006
vietkid_2006 is cool... so far.
Send a message via AIM to vietkid_2006 Send a message via MSN to vietkid_2006 Send a message via Yahoo to vietkid_2006
great work!
OT: does your volume switch on the steering wheel works?!
i have the 6 Disk changer and i want to get the switch and make it work but not sure how.
vietkid_2006 is offline   Reply With Quote
Old 11-13-2009, 12:03 AM   #13
lucifer1
Yes the cruise switches and horn work.
No the volume control is not wired up yet. I need to add a contact in the slip ring to make it work. I have the cruise switches already wired to control the radio when the cruise control is not turned on.
The airbag does not work since my car never came with airbags and I am never go to add control module or sensors
The green car in the background is daily that has been down for a while, 2002 CRV. See more of it herehttp://www.streetsource.com/forum/to...=106624&Page=1
Those weld really aren't that great, the prelude spline outer diameter was about .125" smaller than the mdx and had a gap to filled. It was a quick get it done free weld from a really good welder. You can see what he can do in above link
Old 11-13-2009, 10:49 AM   #14
vinbon63
vinbon63 is cool... so far.
That looks awesome man, great job!
1992 Honda Accord Coupe LX
vinbon63 is offline   Reply With Quote
Old 11-13-2009, 03:58 PM   #15
xaaronx
xaaronx is cool... so far.
Send a message via AIM to xaaronx
wow, that's a lot of work for a steering wheel but mad props! haha those welds look fantastic.
90 ACCORD EX..<-- MR thread
xaaronx is offline   Reply With Quote
Old 11-16-2009, 02:24 AM   #16
cerealkiller93
cerealkiller93 may have said something they shouldn't have...
Send a message via AIM to cerealkiller93
beautiful. Great work man!
Is the bimmer yours? I've got an E30 in my garage. The accord is just my daily driver. The e30 is my toy. I'm a Bimmer-Addict to the bone.
cerealkiller93 is offline   Reply With Quote
Old 11-16-2009, 09:21 AM   #17
Luna92
Luna92 is cool... so far.
great job on fitting the wheel, now when you get the volume working youll be the man in my books!
Under Ground Society
"SLUTS NEED LOVE TOO.....AND A LOT OF DICK!"
Luna92 is offline   Reply With Quote
Old 11-16-2009, 05:51 PM   #18
av6g6
av6g6 is cool... so far.
I love this, it's so clean.
av6g6 is offline   Reply With Quote
Old 11-16-2009, 06:47 PM   #19
excalibur02
Wanna be JDM whore
the mdx wheel matches the palmy grey interior! NICE!
Instagram username MAURO02
Old 06-05-2012, 11:38 PM   #20
8ball
8ball seems to have made some friends! 8ball seems to have made some friends!
I saw a post somewhere where they took an entire column from a cd5 and installed it in a cb7. Not sure what the purpose was how ever. I want something similar to this but with out the welding and such. I dont have the funds. But Im not afraid to swap the column if thats what I need ...
8ball is offline   Reply With Quote
