the clear coating on the lens is starting to flake off is there like kit i could buy to reapply the coating? The lenses are plastic if i remember correctly.
jdm headlight lense recondition?
sand it depending how badly start at 320, 400 , 600 then mothers metal, aluminum polish, and plastex it. no clear coat needed. u can repolish them on the car in about 3-4 months with just aluminum and plastex polish to keep them looking brand new out the box. this method lasts MUCH longer than a WEEK my friend ^^^^^Last edited by xkjnboix; 02-16-2010, 06:14 AM.
Originally posted by zack_odom View PostIm confused as to what the hell you are talking about.
JDM headlights are plastic. Y would they have a clearcoat on them?
kjnboi is right, if you go up in sand grades, you wont have to do it again for a while.
I am the Yakuza CB7!JDM 96spec H22A 178HP 149TQ
"The JDM Fleet"
1993 Accord Sedan - 2.2 JDM H22a1994 Prelude V-Tec1999 CL 3.02000 Prelude2010 Accord Crosstour - 3.5
1993 Mirage S Sedan - 2.0 4G63 Project Evo 2.51994 Mirage S Sedan - 1.5
1991 Isuzu Impulse RS - 1.6 AWD Turbo1993 Asuna - 1.8 "CDM Impulse XS"
1993 Sentra SE-R - 2.0 SR20de1995 200sx SE-R - 2.0 Sr20ve
i dunno if its a plastic film or paint or what but its flaking and im trying to get it looking like new, ill probably have a paint shop do it for me so i wont mess it up. you can kind of see it in the pic but its more noticable in person, the top part of the head light you can make out the line.
It's not a clearcoat. It's a UV film to help protect from the sun (as well as minor scratch resistance). After a bit of searching, it appears some shops may offer a UV coating that can be sprayed on. There are also film applications available (seen a porsche with yellow or blue lenses? Same thing).
Depending on the condition of the lenses you want to start out around with a rather coarse (not so course it leaves permanent scratches and grooves in the lens though) sandpaper. I'd start out with 320 (wet/dry is best, wet paper is a little less coarse than when dry) then move up through the numbers to as high as 2000. Keep in mind to go different directions so you dont wear grooves in the lens. After each coating make sure you rinse the lenses off. When you get to around 2000 then you can use aluminum polish. Don't use a dremel as they spin to fast and cover too small of an area. Small tools like that WILL do damage. Keep to the bigger stuff (I used a powerball on my drill press at low rpms).Last edited by mj213; 02-16-2010, 06:17 PM.
