Go Back   CB7Tuner Forums > Site Features > DIYs > Engine DIYs
Old 05-03-2010, 10:52 PM   #1
HondaFan81
Honda Enthusiast
HondaFan81 seems to have made some friends! HondaFan81 seems to have made some friends!
ENG: Setting TPS
Setting the TPS (throttle position sensor) implies you have made it adjustable from factory preset condition.
TO MAKE TPS ADJUSTABLE:
- Remove the TB from engine.
- Use a cut-off wheel/dremel to make a slot across both factory screws.
- Use flat-head screwdriver to remove.
- Buy 2 screws from hardware store to replace, reinstall TPS with news screws only finger tight.
- Reinstall TB onto engine and connect electrically.
SETTING TPS:
- You will set TPS to 0.45V at TB throttle closed position.
- TPS needs to be electrically connected.
- Turn key to ignition "II" position.
- Multimeter red probe (backprobe) into red w/blk strip wire at driver-side upper shock mount connector.
- Multimeter black probe on negative battery terminal.
- Multimeter set to voltage (you'll be measuring 5V max).
- With probes set, multimeter should read somewhere 0-5V.
- Loosen TPS screws, rotate until 0.45V and snug screws.
- Move onto setting base idle, then base ignition timing.
Reference DIY stickies for base idle & ignition timing procedure below:
http://www.cb7tuner.com/vbb/showthre...04#post2523304
http://www.cb7tuner.com/vbb/showthread.php?t=146242
HondaFan81 is offline   Reply With Quote
Old 12-05-2010, 08:40 PM   #2
XcluziveAZN
XcluziveAZN is cool... so far.
can someone take a picture where the red probe go into?
XcluziveAZN is offline   Reply With Quote
Old 08-26-2011, 06:52 PM   #3
dj_ender
Mod\Dubstep Pusher
FYI, the screws that hold the bracket on the automatic TB's for the other throttle cable fit PERFECTLY for replacing the rivets on the TPS, as do the 2 larger screws holding the spring assembly onto the IAB plate on a6 and h23 IM's
Old 09-11-2011, 12:56 PM   #4
Bad_dude
Bad_dude seems to have made some friends! Bad_dude seems to have made some friends!
Question
Hello,
Could you give the exact size of the 2 screws? I only have one car and cannot take the screws to the store to size fit while the TPS is off.
Thanks.
Bad_dude is offline   Reply With Quote
Old 05-17-2013, 11:41 PM   #5
EsperHamid
EsperHamid is cool... so far.
what's the benefit ?!
EsperHamid is offline   Reply With Quote
