Old 05-13-2010, 02:24 PM   #1
hdjx20
hdjx20 is cool... so far.
Send a message via AIM to hdjx20
91 accord hard to start when cold
whenever i let my 91 accord sit for more than a hour it has a hard time starting. to get it to start you have to mess with the gas pedal to get it to fire. generally speaking on these accords what are the most likely causes of this problem?
hdjx20 is offline   Reply With Quote
Old 05-13-2010, 02:37 PM   #2
jjhdz89
jjhdz89 is cool... so far.
check fuel filters i had this problem and replacing filters cleared it up
I know that you believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant.
jjhdz89 is offline   Reply With Quote
Old 05-13-2010, 02:49 PM   #3
hdjx20
will check. thanks!
Old 05-17-2010, 12:04 PM   #4
hdjx20
any other suggestions?
Old 05-17-2010, 12:05 PM   #5
90_ACCORD
90_ACCORD is cool... so far.
Send a message via AIM to 90_ACCORD
well did you ever try replacing the fuel filter?
90_ACCORD is offline   Reply With Quote
Old 05-17-2010, 01:13 PM   #6
cloudasc
cloudasc is someone to admire cloudasc is someone to admire cloudasc is someone to admire
Let the key sit in the on position for several seconds (5 should be good) before trying to start the car. It gives the fuel pump time to prime/pressurize the fuel system.
You could always check/clean all your grounds, thats free.
How old are your plugs, wires, distributer cap & rotor?
cloudasc is offline   Reply With Quote
Old 05-17-2010, 02:53 PM   #7
hdjx20
ive tryed that sometimes i dont hear the fuel pump priming (who knwos my ears could be bad). plugs, wires, and dizzy are all new within the past 6 months.
Old 05-17-2010, 07:02 PM   #8
cloudasc
Intermittent starting problems can also be caused by the pgfi main relay going bad. Over time the solder connections crack (not visible without a microsope typically). You can refurbish it, by resoldering each component/part one by one (the cheapest option), or you can purchase a new one from honda for about $40. Although main relay starting symptoms typically occur when its hot outside.
Old 05-17-2010, 08:12 PM   #9
bcjammerx
bcjammerx seems to have made some friends!
Send a message via AIM to bcjammerx Send a message via Yahoo to bcjammerx
I do not think it is the messing with the gas pedal that is getting the car to start...more likely the time it takes to mess with the pedal builds gas pressure.
it could be a weakening seal in the fuel pump...someone mentioned this in another similar thread/problem, that guy had to do what was also suggested in this thread...turn the key on and sit for a second. Also wanna check the main relay like cloudasc said.
I'm also guessing it is that since it does this right after you turn the car off...one hour is not long enough to fully cool down.
If it ONLY did this when the engine was cold I would lean towards something else.
____
bcjammerx is offline   Reply With Quote
Old 05-18-2010, 10:19 AM   #10
hdjx20
it is not the main relay and yes it only does it when engine is cold. starts right up when engine is still warm tho
Old 05-18-2010, 10:20 AM   #11
hdjx20
and i am 100% it is the gas pedal that lets me start it cause if i didnt it will stall out right away or jsut keep cranking
Old 05-18-2010, 05:34 PM   #12
chrischhorn
chrischhorn is cool... so far.
i had this issue with my turbo'd cb9. The car would take a bit to start if i just sat there and cranked it. Even if i let the pump prime till the CEL went off. But if I tried to start it with the pedal to the floor, it would start immediately. Never did figure it out but it did bug me. Good luck figuring it out cause i would LOVE to know what it was
chrischhorn is offline   Reply With Quote
Old 05-19-2010, 10:14 AM   #13
hdjx20
going to try replacing the coolant temperature sensor today because i also noticed my temp gauge doesnt work and i had to pull the fuse on my coolign fan because it would keep runnin even with car off and keys out killing my battery. i heard of all of these problems relating to the ect sensor and its only a 25 dollar part so worth a try.
