Try this at your own risk! I am not responsible if you drop the weight on your foot or damage yourself or your property in any way!
So lets say that you have a bolt that you want to get torqued just right. For me that is my main caps and arp head studs. Here is how I get an accurate torque on them.
I used:
engine hoist
adjustable wrench
vise grip pliers
weights (good idea to verify the weight of these)
rope
ruler
Rig everything up like this:
Get the torque wrench level! This is important!
Measure 12" from the center of the 3/8" or 1/2" drive on the wrench. This is the spot to hang the weight from. If your wrench is too small to hang the weight 12" out, then you will have to do some math to get this right. For instance my small torque wrench had the weight at 9" out. for a 35lb weight that would mean: 35x9= 315 in-lbs. to convert that into ft-lbs just divide by 12. 315/12= 26.25 ft-lbs.
Now adjust the torque setting on the wrench until the weight just barely gets the torque wrench to click. Look at the torque wrenches current setting and compare that to how much force is actually on it.
Here is a picture of my setup to get a true 90 ft lbs out of my wrench. The adjustment had to be turned to 104 ft-lbs on this particular torque wrench.
Got it?
I used:
engine hoist
adjustable wrench
vise grip pliers
rope
ruler
Got it?
or you could just buy a toque wrench...after all, those weights are all est. not exact...torque wrench will be more accurate...and even a cheap wrench will suffice...also...this would only work if your part can hang so that your wrench is at a 90* angle with the ground.
__
