Hey Guys,
I've been reading the thread on the V6 Swap...I am the owner of the White CB7 with the V6. I wanted to post in the official thread but i'm not allowed Because I'm new.
If you have any questions I'd be more than happy to help. a lot of the stuff is custom. I used the EG Hasport mouints but had to make custom brackets to attach it to the chassis. I used custom made axels, custom downpipes, and full custom exhaust. The wiring is all custom. We customized a AEM EMS Stand-alone unit to handle the 6 cylinders. The whole motor/Tranny/shifter box and shifter cables are from a 2005 TL. I customized a spacer to fit a cable throttle body on and remove the drive-by-wire.
Here is my official swap list:
Engine Upgrades
J32A3 engine swap
AEM EMS Stand-Alone ECU
Hasport engine mounts with custom brackets
Canton Racing Fuel Filter
Canton Racing Powersteering reservoir
Aeromotive Fuel Pressure Regulator
B&M Fuel Pressure Gauge
Russell stainless steel lines
Russell aluminum fittings
Mishimoto Aluminum Radiator
Mishimoto Radiator Fan 12”
B&M Powersteering cooler
Walboro 255 Fuel Pump
Password:JDM Oil Cap
OD reservoir covers
Greddy Oil Block Adaptor
Custom Short Ram intake
Custom downpipes and exhaust (Rawtek Exhaust)
Custom painted motor
Custom Axels
Custom Clutch lines
Custom fitted throttle body MDX
Custom Fitted Acura TL 6spd Shifter box
Cutom SS Fuel Lines
Custom SS Powersteering lines
Engine Upgrades
J32A3 engine swap
OD reservoir covers
Custom Axels
Custom Clutch lines
Cutom SS Fuel Lines
