I have been researching and used google alot, even went back to the autozone for quick feed back.
i own a 91 accord but recently it's idle speed started jumping from 900rpm to 1500rpm.
- i cleaned out IACV with carb cleaner and found a spare one at a car junk.
- took off the FITV and replaced the Valve inside from an Accura Legend and rubber gaskets as well.
- got an OEM thermostat from honda dealer
- replaced EGR gasket
- found a map sensor on a car junk and replaced it too
- tried adjusting the timing
- got new NRG sprak plugs
- looked for an air bubble and bled the coolant
- got a new PCV valve
and after all of this im about to give up on my cb7 because the idle is not stabilizing.
What am i doing wrong? did i missed something?
WHat is that thing behind the plenum, and doest it play a roll in idle control? is it some sort of a vacuum solenoid ??
__
