JDM H22A Pass emissions?
    Well i got a question. I live in WA and im about to get my swap done. I will be ordering my engine through hmotorsonline. Has anyone done this swap and passed emissions? or does anyone know if it will. it is going in a 1991 accord so it will be going through the sniffer test.
    If your idle is set properly, your cat is good, and the EGR system is functional, it MIGHT pass with the JDM ECU. A USDM ECU will ensure that it WILL pass as long as everything else is working as it should.
      Sweet, Thanks for the info, i was worried about it. is the USDM a p13 as well?
        Yes. Usdm is p13 as well
          it should pass like deev said as long as everything else is in working order. it might cut it really close or itll pass with flying colors.
            Im sure its going to run right. im buying from hmotors and they have a good rep for quality motors. plus i will be replacing the water pump tensioner pulley cap rotor plugs and wires. I will also be getting new cat back exhaust so i would hope all goes well just was unsure about how the jdm ecu makes it run.
