Go Back   CB7Tuner Forums > Parts & Performance > Swaps
Old 12-02-2010, 10:38 AM   #1
ukaccord92
ukaccord92 is cool... so far.
Send a message via AIM to ukaccord92 Send a message via Yahoo to ukaccord92
need some help on wiring
ive come across a hurdle . without noticing i realize the jdm cb7 hasnt a purge valve . it should be vaccum line 20 coming from the sensor box by the fire wall.
since the ukdm h22a2 prelude which has the purge valve i would've to wire up a purge valve in the cb7 ?
secondly the f22a ecu plug the wire(pink) location for ther iab box under the intake manifold is in pin A17
picture 1 accord
and for the prelude plug its A13 should i swap this over ?
pic 2 prelude
'' we racing or you just blowing smoke ?''
ukaccord92 is offline   Reply With Quote
Old 12-21-2010, 05:51 AM   #2
ukaccord92
this might have been a dumb , confusing or too technical question to be answered
or theres some questions that can't be answered ,,,
Old 12-21-2010, 06:59 AM   #3
ukaccord92
obd1 wiring diagram
anyone with a obd1 wiring diagram for a cb7 coupe se-i with bose system ?
this car is jdm spec made in the united states .
