M2S4 tranny
    M2S4 tranny
    I am doing a f23a1 sawp to my white ex and I have the f23a1 (170hp) but I need a tranny. Will a M2S4 work and good as far as gearing IS IT is good for what I am doing? If you didnt know the M2S4 tranny is an h23 tranny.
    Much better than any F22 SOHC tranny... you might see a slightly lower MPG though.
    Checkout my MR: http://www.cb7tuner.com/vbb/showthread.php?t=165984
      For the engine's powerband, the best transmission would be the one that came attached to it from the factory. However, you certainly won't be winning races with that! The H23 tranny has long been regarded as a good balance between the very short gearing of the H22's transmission, and the long gearing of most Accord transmissions. I'd say it's a good choice.
      It's not like the F23 is much of a performer anyway. Good luck with the swap... that's the one engine that everyone seems to have a rough time getting to run right! What ECU are you planning on using?
        f23a1 is 150hp not 170
          150hp, economy vtec... Only slightly better than the F22B1, which is one of the worst F series motors for performance.
            I feel like an f18a carb might be worse
              The F18 has the same head as the F22A... the motor sucks out of the box, but it has potential.
                how are the heads on the f22a anyway?
                  The F22A head has amazing potential. It can outflow the B18C5 (Integra Type R) head.
                  The record-breaking Bisimoto drag Insight runs an F22A.
                    wrong! 150hp stock everything with economy vtec. With a good intake and some good ebay headers and a ecu tuned right I WILL make 170hp at least.If I turbo it IT WILL BE above 250hp.
                    I want this to be my (FAST) cb7.So I think that tranny will be a good quick one.The one that would come with it would be an auto and arnt f23 manual tranny's really rare (I got it and the clutch and flyweel).
                    I know everyone has a hard time geting it to run right but I am taking my time everything.(the engine and tranny are to clean to eat off).
                    I am going to use a p28.
                    I will start a thread for it when start the swap.
