Will using the f22a6 external coil with an h23a1 distributor cause any problems?
Also can i swap the guts from an f22a6 distributor into an h23 one? I have a pretty much brand new a6 distributor and would like to keep it if possible ( or its parts )
Thanks
Oh and why does the h23a1 take 4.5 quarts of oil? is the oil pan bigger? if so can i swap the f22a oil pan onto it so i only need 4 quarts?
Thanks
