Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 06-02-2011, 11:44 PM   #1
whiteboyjune69
whiteboyjune69 is cool... so far.
does my radiator have anything to do with my ac
i was puting freeon in and it started coming out of the radiator the side with the motor. is there something there behide it that has to do with the ac and if so the name of it. if not do i change the radiator and the ac will have no more leaks thanks
whiteboyjune69 is offline   Reply With Quote
Old 06-03-2011, 12:24 AM   #2
Honda Lunacy
Honda Lunacy is cool... so far.
Yes the radiator does in a way have something to do with the ac. Depending on what kind of coolant you have for your ac you will either have a small radiator in front of the regular radiator or you may have a part of the regular radiator where the ac uses to cool things down. So if the freon came out of the radiator (or looked as if it was coming out of the radiator), check the hoses/metal tubing from your ac condenser to the radiator and you will see where it is leaking from. That leak will have to be fixed because if you are releasing freon to the environment you could get a very big fine.
Honda Lunacy is offline   Reply With Quote
Old 06-03-2011, 12:28 AM   #3
CB7Nub
Canadian Regional Moderator
CB7Nub is cool... so far.
There is a separate AC radiator in front of the real radiator, your AC radiator could just be leaking not your full radiator.
Current:
2007 Acura TL Type-S 6MT KBP
Past:
1992 Honda Accord EX-R Sedan - RIP
1991 Honda Accord EX-R Wagon - RIP 10/14/2010
Words change lives. You just got to choose the right ones.
Check out the more active "CB7Tuner Canada" Facebook group for CANADIAN members ONLY.
CB7Nub is offline   Reply With Quote
Old 06-03-2011, 12:52 AM   #4
madmattr6
madmattr6 is cool... so far.
Ac radiator??? The ac and coolant systems are completely separate. The condensor is in front of the radiator.where is the fluid coming out of? The compressor or the condensor?
madmattr6 is offline   Reply With Quote
Old 06-03-2011, 08:14 AM   #5
visualpoet
visualpoet seems to have made some friends! visualpoet seems to have made some friends!
Send a message via AIM to visualpoet Send a message via MSN to visualpoet Send a message via Yahoo to visualpoet
^ This. It sounds like you need to replace your condensor. Once that's done, you'll want to take it to a shop that does AC work, have it pulled into a vacuum and leak tested, you should have them give your compressor a check as well, since it's been sitting empty and therefore unlubricated for a while. After that, you might as well let them charge the system if it's holding.
visualpoet is offline   Reply With Quote
Old 06-03-2011, 10:29 AM   #6
madmattr6
Yea I agree let the shop evacuate and fill ur ac system...you didn't state it but rose lil cans of freon they sell at the auto parts stores are bad for your system...they contain sealant which could clog your entire system.
Old 06-04-2011, 12:38 PM   #7
whiteboyjune69
well the auto parts store told me i hold to change it to the new stuff and i did that and find out it has a leak
Old 06-04-2011, 05:18 PM   #8
ravenexi
ravenexi is cool... so far.
Send a message via Yahoo to ravenexi
OK, I was reading this and really want to set a few things right. Refrigerant never under any circumstances goes into the radiator. They are 2 totally different systems. The condenser is what sits in front of the radiator and is a "heat exchanger" just like the radiator, but just for the refrigerant. No car uses "freon" anymore. That was a slang term for R-12 refrigerant. Since no car has been charged with R-12 for many years now I doubt you still have that in your system. Everything that has made it to a shop should have been retrofitted for R-134a refrigerant by now. From what I read It sounds your Condenser is whats leaking. If your system has been empty for any period of time and you live in a place where the humidity gets high you will also need a new drier. It will pull the humidity out of the air that is entering your system through the leak and it will be useless. If you do not change it out the media inside it will break loose and trash your entire system costing much much more than fixing it right the first time. You can perform this repair yourself but you will need at least a AC manifold gauge set, a vacuum pump and basic hand tools plus the knowledge of how to charge it, how much, what kind of oil to use and how to perform a vacuum pull on the system. If you do not plan on doing future AC work I would strongly recommend letting a shop handle this one because it will cost you less than purchasing the tools and the headache. Also since the system has been opened i would also recommend having it flushed and recharged with a proper oil charge considering thats probably contaminated by now as well. You could always install all the parts yourself then have the shop do the flush and and recharge and save quite a bit of funds. If you do this do the drier last and get it to a shop soon in case you still have another leak and your drier will be messed up again. If the humidity is not bad where your at you can wait longer but here it stays around 90+ percent and we have to work fast with driers/accumulators. They will have to disconnect the drier and the compressor to flush, but thats a lot less than doing it all.
P.S. the cans of refrigerant sold at parts store are the exact same stuff we put in at shops just in a smaller can. We charge our RRR machines with 30 lb cans of the same brand stuff you can get in a 12oz can. However if it does say on the can "WITH STOP LEAK" do not use it!! because it can under the right circumstances trash your system. hope this helps.
ravenexi is offline   Reply With Quote
Old 06-04-2011, 06:51 PM   #9
Tippey764
Silver Member
Best advice i've read for a/c systems on this fourm
Tippey764 is offline   Reply With Quote
Old 06-07-2011, 10:59 PM   #10
whiteboyjune69
i changed it to 134a and replaceed the ac condenser i put the 134 in and it doesnt blow cold i put it between 25/35 the ac turn on but wasnt get cold at al what am i doing wrong
Old 06-08-2011, 11:07 PM   #11
ravenexi
If you charged it with the proper amount. then you are either
A. freezing up from not having a vacuum pulled on it and there is now ice in the system.
B. The media in the drier has given up and trashed your system clogging everything in its path including your new condenser.
C. Your compressor is weak.
D. Your expansion valve is corroded or otherwise not functioning properly.
E. Your heater valve is stuck open.
Good Luck
Old 06-08-2011, 11:15 PM   #12
GeoffM
Administrator
GeoffM seems to have made some friends! GeoffM seems to have made some friends!
I want to point out that without a radiator, you cannot have AC. This is due to the fact that you need a radiator to run the engine, which is required to run the AC.
MRT
Originally Posted by Tippey764 View Post
sneaky motherfucker
GeoffM is offline   Reply With Quote
Old 06-08-2011, 11:31 PM   #13
Tippey764
Silver Member
Air cooled engines
