To keep an operating key or same key as your car.
I made a very simple DIY.
Credit due to cp[mike] for the orignal. This one just has lots of pictures. <3
This is what you'll start off (From a sedan The coupe is simple just pull the rod out)
The sedan is a little more complicated. You have to use a flat head screwdriver to push down the pins on either side.
After that just unscrew the bolt. Then there is a notch you have to line up to take out.
No more golden bolt.
You can see the notch at the top right. A cut out of the blue metal at the base of the shaft.
Both locks taken out of the trunk. Sedan left (longer) coupe right (shorter).
Another view. Sedan left Coupe right.
Take out this pin. Flat head will pry it out quick.
Both pins taken out.
Now to take off this silver cap. (It was a challenge for me if the is any simpler way let me know)
I used these tools
First i used the flat head and pried in the square hole. No to rough just until you see a gap.
Here is the gap.
Then just push the silver cap up by the lip.
I also found it helpfull to wiggle it from time to time. To loosen the crimps.
Almost off.
This is what it will look like when it is off. Take off the spring at the end.
Then push it up from the bottom. watch out for the golden keys on either side. They will fall out.
All the parts.
Next is switching the wight adapters. its as easy as slide one out and slide one in.
Totally taken apart.
Slide the longer white adapter if switching to a sedan trunk lid. Short for coupe lid.
Make sure the square indent here (pointing at) is lined up with the square hole at the top just above the keys.
Slide the desired key lock into the sedan(long) or the coupe(short) sleeve. Be carefull of the keys. You'll need to push them in as you go.
Put the silver cap back on. Match the Square holes and there is also a slot on the back.
Then just re-attach the white rod clips.
After that install.
There ya go now one less key on the key chain.
Originally posted by Accrdwgnguy
View Post
I used these tools
Here is the gap.
Almost off.
All the parts.
After that install.
