Okay so I have some pretty bad glass on my car and it was time to make it shine on the outside! So I polished them! ONLY USE THIS D.I.Y FOR THE OUTSIDE OF THE CAR!!!!!
The glass is quite like a headlights glass so it is really similar to cleaning headlights....
The things you will need include:
(2) microfiber cloths
terry white cloth
headlight restoring solution (I used the one with the blue liquid inside of it)
sandpaper (2000 grit)
and plenty of water!!! I used a water bottle because I was doing this all in the garage.
First of all you must put the solution on the microfiber cloth and smear it all on the glass
Next take the water bottle and put water all over the window
Then take the sand paper and go in a circular motion when sanding, make sure you always have the surface wet enough! Keep sanding until you can see clearly through the window...
now take the terry cloth and wipe off all the solution and you will have little smudges here and there
Finally take you microfiber cloth and wipe the window, Streak free and brand new looking!!!!
terry white cloth
But if I restore again I use glass polish!
it took me 15 minutes for all the windows
