gas/temp gauge problems
    my gas and temp gauge stopped working the other day and i dont know what the problem is. i have bought 2 different gauge clusters in the past week and that still didnt fix it. so the only thing i can think is maybe for the gas is the fuel sending unit but as far as the temp i have no idea. please someone help me so i can fix it.
    www.rms-usa.com
    The gauges will just read what input is being sent to it. No input = no reading. Find out what the temp and gas gauges have in common and trace it back. A wiring diagram will probably come in handy.
    Former: 90 Accord EX Coupe, 93 10th Anniversary in Frost White
    1985 Volvo 245 manual [IPD lowering springs, IPD sway bars, OEM Virgo wheels, 1977 quad round headlights, 1978 grill]
    2001 Mazda B3000 SE 4x4 extended cab [stock except for CB radio]
    2008 Ford Escape XLT [bone stock]
    2015 Toyota Prius Three with solar roof [rear diffuser, Vision Cross wheels... cheaper than steelies!]
      where can i get a wiring diagram for the gauge cluster? if it is too much of a hassle i am just going to go to autometer gauges
      www.rms-usa.com
        for the temp, could it be the temp sender thing that goes into the left side of the head? I think thats what it is, but dont quote me on it
        *on the lookout for an h22 swapped 5 spd accord*
        now for my P.O.S winter car/daily
        1992 4dr escort lx hatch
        NO MUFFLER-wrx sti tip(got fo free)
        5 spd
          i was thinking it could be the temp sensor on the top or bottom radiator hose but if the sensor was bad wouldnt it throw a code?
          www.rms-usa.com
            did you mess with any of the screws on the gauge clusters? because those screws act as a ground to get the signal through to the temp/gas/speedo/tach. if they are not tight it would not complete the circuit.....or yeah you could have a bad temperature sending unit, which is located on the thermostat housing....or you could have a bad fuel sending unit, which is located under the backseat inside the gas tank.
