Thread Tools Rating: Thread Rating: 9 votes, 4.67 average. Display Modes
Old 12-31-2011, 09:58 PM   #1
lucifer1
lucifer1 seems to have made some friends! lucifer1 seems to have made some friends!
lucifer1 : 1990 Accord LX
This originally was my grandmothers car which became my parents spare car. I borrowed it from time to time. One of those times I had an accident so now it is mine. The process of fixing it began a while ago, then sat, but now is back on track.
Exterior
Interior
Underhood
  • Relocated FuseBox
  • Relocated Battery
  • Hidden and Rerouted Wiring
  • Billet Radiator Mounts
  • AEM Intake
Suspension
  • Airlift air spring shocks
  • Modified Integra shock forks
  • Modified front upper a-arms
  • Modified radius rods
  • Rebuilt and raised shock towers
  • Modified front inner wheel wells
  • Shortened and reshaped front spindles
  • Modified rear trailing arms
  • Modified rear lower control arm
  • Modified rear spindles with lowered shock mounts and spherical bearings
  • Custom adjustable rear upper arms with spherical bearings
  • Modified rear wheel wells
  • Accuair Switchspeed
  • Accuair Vu4 valve block modified
  • Viair 444c air Compressors
Brakes
  • Front 2 piston Odyssey calipers
  • Rear 12.3" rotors with Odyssey calipers
  • Drum parking brake conversion
Wheels/Tires
  • 17" Boyds Wheels
  • 205/40-17 Falken Azenis
Electronics
Future Mods
  • lowering
  • Suede/leather interior
  • Audio System
  • Billet grill
  • Billet bumper grill
Old Mods
Mdx steering wheel
Variable wiper mod
Lighted mirror switch
Cl Homelink
Cl trunk actuator
Molded RSX mirror Switch
Lighted Legend Window Switches
Boyds Wheels
Entry lighting in door handles
Lighted trunk release switch
Steering Volume control by cruise buttons
lucifer1 is offline   Reply With Quote
Old 01-01-2012, 12:08 AM   #2
Wickit
Wickit is cool... so far.
Steering wheel looks good!! Not feelin the wheels tho, just my opinion :P can't wait to see her done!
1993 10th Anniversary MRT
Originally Posted by The G-Man View Post
For that money, yes. But my dick isn't big enough for that shit.
List of all my cars to date
Wickit is offline   Reply With Quote
Old 01-01-2012, 12:30 AM   #3
'93CB7Ex
i like all the little light up mods you've done.
Old 01-01-2012, 09:41 PM   #4
lucifer1
primed
rear primed. Shaved emblem holes and antenna
Moldings and rockers primed
Core support painted
color in the sun
Quick fix. It will get redone when the engine is pulled next year and the whole bay done
Painted fan shroud
Painted mirrors
Filled license plate holes
Old 01-01-2012, 09:48 PM   #5
itstatcb7kid707
itstatcb7kid707 is cool... so far.
Send a message via AIM to itstatcb7kid707 Send a message via MSN to itstatcb7kid707 Send a message via Yahoo to itstatcb7kid707 Send a message via Skype™ to itstatcb7kid707
nice
itstatcb7kid707 is offline   Reply With Quote
Old 01-01-2012, 09:54 PM   #6
crazymikey
crazymikey is very helpful crazymikey is very helpful
I like this....alottttt
crazymikey is offline   Reply With Quote
Old 01-01-2012, 10:03 PM   #7
cb7sk8rdude
cb7sk8rdude is cool... so far.
WOW thats sweet
cb7sk8rdude
cb7sk8rdude is offline   Reply With Quote
Old 01-02-2012, 02:59 PM   #8
lucifer1
I started fitting rear handles on the front doors.I looked the DIY on here but it lacked a bit on fitting the handle.
It fits like this before modding.
The mounting posts are deeper and angled different that the front.
After grinding down the posts it still sticks out
The actual cutout in the door is deeper on the rear than the front. The handle is also a tiny bit wider all the way around.
I ended up grinding down the sides and bottom as well as the back side
I also ended up grinding some plastic that was rubbing the outside skin
The lower lip on the opening was also causing the handle not to fit on the bottom so I ground it off.
The bolts holes are also off a bit so I filed them
After opening up holes and grinding lower lip
Now it sits flush
Old 01-02-2012, 03:03 PM   #9
lucifer1
Shave hood squirters
Since the holes are still fairly small, I decided to just build up weld on top of weld to fill the holes. I think it is better to drill out the holes with a step bit and make round filler pieces to weld in but I wasn't that motivated.
Old 01-02-2012, 03:06 PM   #10
Mike1357
Mike1357 is cool... so far.
I might've posted here before the October revert, but this car is looking really nice so far and I love all the little mods you've done here and there. Can't wait to see what else you come up with.
Mike1357 is offline   Reply With Quote
Old 01-02-2012, 03:13 PM   #11
lucifer1
I rigged up some window switches from a legend that light up
I filled the hole for the window lock and molded in a newer mirror switch from a RSX
Adding leds to the handles that will light up when alarm is disarmed/dome light is on. Once the handles are painted, the wires will glued in
Added a light to a non lit trunk switch
Old 01-02-2012, 03:29 PM   #12
lucifer1
Molded in Vigor light into the pillars. All the upper trim will be smoothed painted.
Old 01-02-2012, 08:28 PM   #13
crazymikey
Just too many damn cool little mods.
Old 01-04-2012, 05:23 PM   #14
Jarrett
Interesting little project you've got going on there. It looks familiar to something that's on my current agenda.
Tippey764 is seemingly always having me check Legends for parts and he mentioned this briefly one time as something he would like to try. So, I stole the idea. Not to take credit, just because I like doing stuff like this.
Old 01-04-2012, 06:28 PM   #15
Daheavyking
Daheavyking is cool... so far.
Send a message via AIM to Daheavyking
This is looking good man!!!!! Im keeping my eye on this!
My coupe!!!
Originally Posted by Racer_XXX View Post
Daheavyking is offline   Reply With Quote
Old 01-05-2012, 02:13 AM   #16
lucifer1
2 door lighted switch hybrid looks like a lot of work. The four door one looked to be a pain so i just put the whole legend switch in but you cant do that with the two door.
Unless of course you add the power rear vent windows. Then you can have an excuse to use the four door switch.
My crv has only the auto switch illumnated but had empty spots to add leds for the other switches. Finding switch caps without paying for a whole switch has become very difficult. The only caps that fit are crv and 4 door civic master switches. The 2dr civic and rsx caps look the same but are different. It will take 3 switches to get the caps
Old 01-06-2012, 04:15 AM   #17
Jarrett
It is indeed a lot of work. But it's pretty self-explanatory and not something I have to think very much on. It's on hold for now while I wait on 1mm shrink tubing and white 3mm LEDs to come in the mail. Have you been using SMD LEDs for any of your proejects?
As for those CR-V switches, it looks from the picture like if you had an extra LHD switch and two more RHD switches then you could make all of them with the auto function. The CB7 one does not look that easy unfortunately. On F-bodies I know you can add the auto-down switch function to the passenger switch on the driver's side also. And I'm pretty sure that one Acura RL switch would give you all the caps you'd need.
Old 01-10-2012, 11:51 PM   #20
texas_cb7
texas_cb7 is cool... so far.
ur cb look sick bro,luv the color & the wheels
texas_cb7 is offline   Reply With Quote
