I picked up a charging system upgrade kit from CE Auto Electric Supply and thought I'd share the install process.
The kit I picked up was the 2CSUKTPB-5, 5 foot 2 AWG Upgrade Kit for Top Post Batteries and opted for the FHANL1 to fuse the charge lead for protection.
This is what is included in this particular kit.
- 5 feet of red 2AWG cable terminated with a 5/16” eyelet on one end.
- 5 feet of clear 2AWG cable (for the ground) terminated with a 3/8” eyelet on both ends.
- 2.5 feet of clear 2AWG cable (again for ground) with a 3/8” eyelet on one end.
- 4 feet of clear 8 AWG gable (smaller ground) terminated with a 1/4" eyelet on both ends.
- 2 new heavy duty battery clamps.
- Zip ties, bolts, washers, etc. LOTS of nice top quality hardware.
Tools needed:
Different sizes of wrenches and sockets. 8mm, 10mm, 12mm, and 14mm.
Drill and dril bit. Gauge 'S' or 11/32" drill bit for the M10 x 1.25 bolt I used.
Tap. M10 X 1.25 metric tap. Use the correct size tap for the bolt you decide to use for the ground to frame connection.
Knife or other cutting tool.
Strippers (the wire kind... though the other kind wouldn't be bad, just distracting).
Recommended tools:
Large gauge cable cutters.
First off was dealing with the slight issue of the new cable lugs being slightly too large to fit the alternator, so I popped the alternator off:
As you can see in the picture below, the terminal for the new charge lead wouldn't fit because the factory isolator on the alt wasn't designed for such a large lug and of course with everything Honda related, it's too damn small!
So I took a few minutes and modified it for a perfect "OEM" fit.
Once that was complete I gathered up all of my goodies and got to work!
First up, getting the new ground connected from the alt to chassis. The options are slightly limited, so I connected the ground to the top of the alt mount/bolt location.
Next up, grounding the alt to the frame and grounding the bat to the same location. Lucky for us we have some holes located directly under the battery tray.
So I picked the hole I wanted, drilled it out the the appropriate tape size, tapped it, and installed both grounds.
This kit came with a 10mm bolt to be used on the back of the alternator for the new ground, but since I couldn't use it for that, I used it to bolt down the grounds to the frame (used the supplied star washer, flat washer, and lock washer as well).
Drilled:
Tapped and paint removed:
Lithium grease applied and cables bolted down:
Next goal, installing the new charge lead to the alt. The original alt lead doesn't go directly to the battery, instead it disappears into a wire loom that snakes it's way over the valve cover, under the intake, and a few miles latter pokes itself up out near the underhood fuse panel.
So not wanting to rewire everything (YET), I connected the new lead along with the original to the alt.
Next up was finding a location to install the fuse holder for the charge lead... on top of the battery is literally the only flat spot, so why not? I'll be making a custom battery hold down with a fastening location for the fuse holder this spring when it's not freezing outside. So for now, the holder will be 3Med to the top of the battery.
So with the positive battery terminal temporarily installed and the fuse holder location picked, I stripped the cable, installed the reducer (supplied with the fuse holder), and got the charge lead into the fuse holder.
Using my super trusty Gerber knife.
Cut some more cable for the fuse holder to the bat terminal and gave it the same treatment (stripped both ends, reducers, and clamped in)
Now lucky for me, I had just enough cable left to make a new lead to the started, so I tossed on a lug, some heat shrink, and BADOOOOM! New starter cable!
So with the positive leads all terminated the grounds were next.
This kit came with four feet of 8AWG with eyelets installed on both ends, so I was able to upgrade the smaller ground leads.
Same deal, measure, cut, strip, clamp.
And I was done!
I installed some Techflex sleeving on the charge and ground from the alt that run behind the radiator for some extra protection.
These instructions can be applied to other similar kits OR you can even build your own. I just opted for the convenance of this kit since it came with everything and I mean EVERYTHING.
Hope this helps some people out there.
Tools needed:
Recommended tools:
Drilled:
And I was done!
