I decided to make this because i thought it was a cool idea and its totally removable from your hood.For this project i used PLASTIDIP for my bra. I couldnt find one anywhere and the ones that have to be made take forever to come and im a impatient person when it comes to my car parts.In the end this is what you should end up with:
Stuff you need:
2 cans of plastidip (Homedepot or Lowes )$6.00 a can
Masking tap
Newspaper
1)Make sure that your hood is clean of any dirt or grime
2)pop the hood open and lay down the newspaper over your lights and fenders and then shut it.
3) place one long strip of tape from one end of the hood to the next. you can adjust the tape to make the bra bigger or smaller or however you want it
4) cover the rest of the hood in newspaper and mask off the top part of your bumper.
5) Spray the plastidip on the uncovered area. When your spraying the platidip its gonna look like bedliner at first but keep spraying it.You want to put a nice thick coat on but not too much that it drips(i put 2 thick coats).
6) Once you are done spraying remove the newspaper and tape.This will prevent the plastidip from ripping when its dry and it leaves a smooth edge.
It takes about 3 to 4 hours to fully dry and it should have a little texture to it but not much.If you get overspray on your car you can just rub your finger across the stuff and it flakes off real easy. The plastidip does not come off when you wash the car or dry it. If you do decide to take it off just pick at a corner and it should rub off in one piece.This is for those who cant find a bra like i couldnt so i improvised .This is also good against rock chips too
Enjoy everybody!
Stuff you need:
Masking tap
Newspaper
Enjoy everybody!
VS
