Hello everyone. I'm going to start a turbo build here on the beginner threads. Any questions anybody has I'll do my best to answer, and I know that I've got some questions too, so any help is appreciated.
So to start off I've scowered the forums and google for information on my vehicle, and compiled a list of parts to get me started. For those of you with the knowledge and experience, if you see something you think is just a terrible idea, or know of a better way feel free to throw your .02 in. Thanks guys, heres where my list is at so far.
P.S. All prices were rounded up to make math easier.
1. ARP Head studs - Ebay.com - $135
2. Fel-Pro Head gasket kit - summitracing.com - $130
3. P06 ECU - Craigslist, junk yard, Ebay.com - $25-$50
4. Honda water pump - estore.honda.com - $72
5. OEM Honda oil pump assy. - estore.honda.com - $270
6. Custom made exhaust system - Not yet priced
7. High flow catalytic converter - Not yet priced
8. Walbro 255 in-tank fuel pump - Highflowfuel.com - $80
9. H23a intake manifold and throttle body - Ebay.com - $130
10. Piston rings - Not yet priced
11. OEM Honda crank and rod bearings - estore.honda.com - $110
12. 16g turbo - Ebay.com - $200
13. DSM 1st gen 450cc Injectors - remanufactured - injectorwhse.com - $144
14. 2.5" universal fmic piping - Ebay.com - $150
15. Bisimoto H-beam Rod and 9.1/1 Piston Combo (good for 300-800whp) - bisimoto.com - $790-$820
16. H22 LSD Transmission - Not yet priced
17. Stage 2 Clutch kit - Not yet priced
18. DSM exhaust manifold - Ebay.com - $60-$80
Note: I went with an H22 LSD transmission (as opposed to the f22 or h23's) because I feel that the shorter gears will go well with the larger 16g turbo.
Anything you guys have to add that I missed feel free to add. I'm looking to make anywhere between 220-250hp.
Stay tuned because she is going to get a compression test done next monday! This turbo build may turn into a complete bottom end build! I'll post pics as I go along. Thanks for reading!
Update: Please be aware, as brought up by other members, you will need oil lines, a catch can, wideband o2, probably want a boost gauge, and definitely an oil psi gauge. Also I haven't been able to locate a downpipe made for this type of set up, and so you will need to have one custom made. It has also been brought to my attention that 3" fmic piping is overkill for this setup. You wouldnt need that size unless going for more power, up over 300hp. For my goals, 2.5" is sufficient.
Please keep in mind this is my FIRST turbo build, so I will not immediately have all of the answers. The above list is the product of about 2 weeks worth of searching and cross referencing. I still have very much to learn about boosting cars, so please do not use my list without doing your own researching.
Taking other members suggestions into consideration, I searched for forged pistons for the f22. If your wondering about using h22 forged pistons because you cant find any forged f22 pistons, it is possible if you have your block bored to 87mm. From what I've read, the standard for the f22 is 85mm. Anyways, a majority of people are suggesting use of bisimoto.com or f22parts.com.
At least here someone can say that and not get post-count credit for it.
My intentions ARE to follow through, I make a good enough living to make it happen, not just another "noob" that talks about how much he wishes to have a boosted vehice. I don't know if you're referencing me when you talk of noob-whoring, but that was not my intention, I couldn't care much less about my post count. If you look at my few posts, each one was either me responding to somebody posting info on my thread or trying to be helpful about topics I've already researched.
Super excited about that because this thing has such high mileage. (259,000). For those of you who don't know with the f22 you want to see between 160-180. I believe your numbers should be within 10% of eachother. (Correct me if I'm wrong) Anyhow my H23 Intake manifold is here as well, so I will probably go ahead and put that on this upcoming weekend. Perhaps I'll post some pictures of the swap as I go along.
