Hey I have a cb7 and I was wondering if the f22a6 tranny would fit the f20b? If not what would be a good tranny for the f20b?
f20b with f22a6 tranny
For 9 years, people on this forum have been saying any FWD F or H series transmission will bolt to any FWD F or H series engine. It was true before that time. It was true for that whole 9 year period. It will continue to be true. Forever.
Yes, it will bolt up. Yes, you will drop out of VTEC every single time you shift.
The transmission that originally came attached to the engine would be your best option, as the gearing is correct for the engine's powerband. An H22 transmission would be your next best option. H23 after that.
Searching will REALLY be beneficial. This stuff has been answered many times in the past, and much of it can be found in the "sticky" threads in the Swaps section.
You will need to tap new holes in the transmission casing. Easy enough to do.
Also, since you're a noob... what are you planning on doing for engine management (ECU) for that F20B?
