I saw lots of videos and most are good, especially the one from Eric The Car Guy, but his was on the Odyssey so the design is similar to our CBs but not the same. So I found the video below to me exact as our CBs which make it more practical for us. I did a few Corollas and they are not the same. So when I took my CB drums off and Uh! Not the same.
The Video.
I hope it helps. To be honest it's the best video I have found for our CB drums.
Remember some important tips guys. Stay away from the brake pedal and hand brake if the drums are off.
Adjust the drums with the slight drag, I mean slight. If the drums are still smooth without the raised outer ridge, then they do not need to be grind down.
Watch when taking the upper springs off that you don't let the shoe push the cylinders too far toward the other side or the fluid will come out and you need to bleed the system.
Always make sure the drums are on, once again, before pushing the pedal or pulling the hand brake.
For God sake, take you time.
The Video.
