Go Back   CB7Tuner Forums > Parts & Performance > Appearance > Interior
Old 04-05-2005, 11:32 AM   #1
uncle_el
Moderator
uncle_el is cool... so far.
what seats work in an accord? an faq of sorts, pics included
i want to fit "x" seat into a cb7. what do i do?
Originally posted by uncle_el
i don't know about fitting seats that weren't designed for your car. while you may be able to get a seat that you desire to fit onto a bracket that will fit your car, you may end up testing the waters if you get into an accident. but i suppose that you are at the mercies of past honda engineers if you get into an accident.
your best bet is to look at the specs of the seat(s) you are inquiring about. you need to find the length and width of the seating surface,and compare it to the length and width of your current stock seat. if the seat is too wide, it won't fit properly in the car, regardless of the brackets on the bottom.
after that, you would need to take a look at how the brackets are positioned on the bottom of the seat.
then, you'll need to find out the length of the brackets on the desired seat. it's best if you can use the brackets that exist in the desired seat, so as not to rip out the brackets and put in your own, as it will decrease the integrity of the seat itself. it makes sense to find a bracket length as close as possible (if not exact) to that of the cb7, so that it will fit in the tracks.
synopsis: dimensions of desired seat compared to the stock seat, bracket positioning, bracket length of desired seat.
you could theoretically, if you didn't care about having a seat that slides forward and backward, bolt the seat directly into the floor. i've only seen it done in a 240sx, and it was a show car at that.
my comment out of this thread:
http://www.cb7tuner.com/vbb/showthre...t&pagenumber=1
bustedlx's comments:
Originally Posted by BustedLX
It will require custom fabrication. The Accord's rails are unique in the way they mount to the seat. They are very different from all other Honda's.
custom seat brackets. how would i go about doing that?
Originally Posted by Slateboy
I was going to make a DIY on this, but here's a quick overveiw:
Fact: I have Tenzo R seats and no brackets.
Problem: I couldn't find a working bracket.
Here's the quick overview:
First I took an air-driven cutting wheel and cut the Accord seats off their sliders. It's not easy. I cheated and used a band saw to cut through the majority of the heavy metal. The brackets look like they're just riveted down, but there are also tackwelds that you cant see. However, if you cut the steel away, and slice off the tackweld points and rivets, you come away with a sliding assembly.
Now I installed the empty sliders in my car and measured the distance between the center of one, to the center of the other. This plays as an empty canvas to mount any type of seat on.
Then I measured the distance of the center of the bolts on the Tenzo seat. I can't remember without looking, but let's just say they were 2 and 1/2 inches difference from the distance of the sliders from eachother.
I went to the local big hardware store, and picked up some welding steel. It is a long flat piece of steel that is easy to work with. I subtracted the distance of the seat bolts from the total distance between the two sliders. Divided that in half. Then drilled two holes in the welding steel this distance apart. For this equation, it would be 1 and 1/4. I did this four times for each seat. This creates a piece of steel that makes up for the difference between the width of the seat mounting bolts, and the sliding assembly.
I then measured the lenthwise distance of the bolts and drilled two holes in each slider this distance from eachother. The metal brackets made of welding steel then bolted onto the seats, then into the slider assembly.
This effectively, when done with properly hardened bolts serves as a safe way to DIY brackets to fit any application.
so, what seats fit?!?!?!
prelude
93accordex's from years ago
shawn.hayden's
phatdoughnut's (jdm prelude seats)
shawn.hayden's comments about the prelude seat swap:
Originally Posted by shawn.hayden
The seats sit a little lower than stock, but they have more support for you body (for me at least, maybe not for bigger people) than the accord seats.
We ended up having to customize the accord bracket mount holes (where it connets to the actual seat). We moved the holes as far as possibly over, (with it still having some room for give way)in order to widen the width of the prelude seat mount.We used the strongest bolts we could find to tighten it all back up... end result is a seat thats in there REALLY tight.
The mounting brackets didn't line up perfect, but I saw the same problem when I took my accord seats out and put them back in. You kinda gotta force one side in because the seat fits in there REALLY tight (a tad bit tighter than the accord, but not to the point where it's liable to break the bolts.) The holes were maybe 1-2 cm's off so just had to pull em over a tad to get em in.
The accord bracket pieces are VERY similar to the prelude and took very little modification to make them fit.
some people would probably still say that the seats are safe, but I got a friend of mine (slow904door as a matter of fact) to yank on them pretty good and they aren't goin anywhere (He's a pretty big guy as some of you will see this weekend)
overall I'm glad I took the 2 days that it took to do this, it was pretty tough at times trying to figure out a way to make em work, but with help from my friends (slow904door, MUGENS2002, and another guy thats not on here), we got it done.
I'll try to get some pictures up tommorow
EDIT: Oh and the seat goes back about the same, maybe a little farther
write up on accordinglydone by superorb on prelude seat swap
integra gsr
Originally Posted by AlmightyAccord
i dont know where i got this pic, but it was saved in my accord pics folder
but those are GSR seats in a 2dr accord!
integra type r
Originally Posted by k-mart
Type R Recaro's^ in Bille's car
s2000
lexus is200
subaru srx sti recaro
dutchaccord's
6th gen accord seats
primocb7's
crx si seats
bstedcb7's
bstedcb7's diy on crx si seat install
rsx
pics coming...
word of advice regarding newer seats
Plus something you should consider when buying those seats, all RSX's, EP3's, S2K's and etc. have VIN's on the seats now. So if you get pulled over and a cop inspects them, your at best getting the car impounded for improper VIN's. That is if the seats come back as being stolen.
I know atleast here in South Florida that has pretty much stopped the sale/use of those kind of seats because the cops pull over everyone rocking them.
uncle_el is offline   Reply With Quote
Old 04-05-2005, 12:07 PM   #2
phatdoughnut
phatdoughnut is very helpful phatdoughnut is very helpful phatdoughnut is very helpful
Send a message via AIM to phatdoughnut
Small little note.
i think i am the only one with the prelude seats in a 4door and they DONT slide back as far as the old seats... i have to bend my legs a little and im 5'11''
phatdoughnut is online now   Reply With Quote
Old 04-05-2005, 02:55 PM   #3
rebels
rebels may have said something they shouldn't have...
i sell aftermarket sliders for seats if any people need them.. they can be used on OEM seats or any brand racing seats.
$65 for both sides.
rebels is offline   Reply With Quote
Old 04-12-2005, 05:25 PM   #4
h22sparkle
h22sparkle is cool... so far.
yo rebels will your sliders fit the tenzo r rally evolution seats? and do they bolt onto the seat aswell as the frame and slide back and fourth?
I dont know it seems to me theres alot of posers on here or lames that like to buy other peoples built cars so sad. As for me im one of a kind the fastest of my own kind.
h22sparkle is offline   Reply With Quote
Old 04-16-2005, 09:13 AM   #5
uncle_el
Moderator
more pics of bstedcb7's crx si seats:
Old 04-27-2005, 07:54 AM   #6
jus_business932
jus_business932 is cool... so far.
anybody do a backseat swap???
The Car
jus_business932 is offline   Reply With Quote
Old 04-27-2005, 08:21 AM   #7
BIGTUFFGUY
BIGTUFFGUY is cool... so far.
Send a message via MSN to BIGTUFFGUY
im very interested in doing the 6th gen accord seats,
they are easy to replace, and the back would be the same too?
also, if they are powered seats, how do i feed them? and if they are heated, where do i get the buttons installed?
BIGTUFFGUY is offline   Reply With Quote
Old 06-01-2005, 08:53 AM   #8
cp[mike]
cp[mike] seems to have made some friends! cp[mike] seems to have made some friends!
Installed 99 (5th gen) lude seats in my CB7 last night, it was pretty easy, but harder than 4th gen lude seats. I swapped the inner slider (closest to the center console) from the accord seat onto the lude seat, it wasnt perfect but its easy to get it to fit... gonna take it off and enlarge one of the holes to make it a little better. since the inner slider is an accord one, it bolts in fine, then you need to pull on the outer slider to get it to line up with the hole, and lastly the back corner closest to the rear doors im going to need to bend and drill, but as of now, 3/4 bolts are in and the seat is sturdy, and they slide all the way forward and back and they are installed in my SEDAN. I will get pics eventually for your collection el!
Old 06-06-2005, 10:13 PM   #9
FLIPCB7JDMH22
FLIPCB7JDMH22 is cool... so far.
Send a message via AIM to FLIPCB7JDMH22 Send a message via Yahoo to FLIPCB7JDMH22
glad to know that i can install lude seats on mine..i got a source..since my aunt wrecked her lude 2 months ago and the car is sitting in my garage collecting dust..haha.. my aunts wrecked lude is 92..will it fit my 2 dr CB7? the only problem i have is getting it off from my aunts car and getting it installed into my car becuase i limited tools...but other than these im all good..thanks for this write up.. good job!!
FLIPCB7JDMH22 is offline   Reply With Quote
Old 06-23-2005, 05:35 PM   #10
uncle_el
Moderator
more s2000 seats
honda304's
Old 08-15-2005, 04:06 PM   #11
snailin91
snailin91 is cool... so far.
i have 91 GSR seats. had to make adapters. much comfyer.
snailin91 is offline   Reply With Quote
Old 08-28-2005, 09:07 AM   #12
90ex-r
90ex-r is cool... so far.
Send a message via MSN to 90ex-r
will an 89 honda accord interior (door panels and seats) fit my 90 accord?
90ex-r is offline   Reply With Quote
Old 08-28-2005, 10:05 AM   #13
PRIMOCB7
PRIMOCB7 is cool... so far.
Send a message via AIM to PRIMOCB7
WTF?!? why would u want an older gen interior.. it would require major fabrication to get the seats and panels to fit into the cb7. but you know what, give it a try and let us know how it turns out
5.6L V8 32V DOHC
JDM HERITAGE - US BUILT
PRIMOCB7 is offline   Reply With Quote
Old 09-02-2005, 01:42 PM   #14
jdmaccord253
jdmaccord253 is cool... so far.
Send a message via AIM to jdmaccord253
i got red sparco sprints in mine...ill send them later..
jdmaccord253 is offline   Reply With Quote
Old 10-11-2005, 08:43 AM   #15
DatFlyBoy
DatFlyBoy is cool... so far.
Send a message via AIM to DatFlyBoy
got front GSR leathers, what backseats fit CB7s?
DatFlyBoy is offline   Reply With Quote
Old 11-20-2005, 09:34 PM   #16
heylookitsdylan
heylookitsdylan is cool... so far.
Send a message via AIM to heylookitsdylan
so s2k seats will bolt right in?!
heylookitsdylan is offline   Reply With Quote
Old 11-23-2005, 06:49 PM   #17
mondojackal
mondojackal may have said something they shouldn't have...
Send a message via AIM to mondojackal
99 is 5th gen?? im pretty sure that if 90-93 is 4th gen, that 94-97 is 5th gen, but maybe im just an idiot....
mondojackal is offline   Reply With Quote
Old 11-23-2005, 06:58 PM   #18
uncle_el
Moderator
please note that he is referring to preludes (lude), and not accords.
92-96 prelude is the 4th gen lude, 97-01 is the 5th gen (and last) lude.
http://www.92lude.com/prelude_specs.htm
http://auto.consumerguide.com/auto/u...x.cfm/id/2265/
Old 12-15-2005, 05:29 PM   #19
mondojackal
yeah, i dont need links to pages, thanks anyways...
Old 01-09-2006, 05:16 PM   #20
JDMH22ACB7
JDMH22ACB7 is cool... so far.
too bad those super tight black S2K seats were sittin amongst that old-lookin maroon interior. haha. took me many hours to rid mine of the maroon.
JDMH22ACB7 is offline   Reply With Quote
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
