Old 05-29-2014, 07:14 PM   #1
dahubby
dahubby is cool... so far.
EXT: stock rear wing from accord
Not sure how many people will need this but if you want to install a rear wing from another year accord, there is a little process involved. I found an LED one from an 07 accord and decided to make a DIY.
Tool needed.
Air Grinder or Dremel
Drill with bit
Grinding stone or sandpaper
masking tape
silicone
electrical tape test light
[IMG]DSC_0016 by alwaysdeployed, on Flickr[/IMG]
[IMG]DSC_0017 by alwaysdeployed, on Flickr[/IMG]
first i mocked up the wing to the car so i could make sure that it was centered and get the holes drilled in the right place
[IMG]DSC_0015 by alwaysdeployed, on Flickr[/IMG]
Then i traced out my hole patterns on both sides
[IMG]DSC_0001 by alwaysdeployed, on Flickr[/IMG]
[IMG]DSC_0002 by alwaysdeployed, on Flickr[/IMG]
After i traced out my bolt patterns i had to cut under them to allow access for the nuts to be put on. I marked the areas with a marker. Be sure to watch the wires on the driver side.
[IMG]DSC_0003 by alwaysdeployed, on Flickr[/IMG]
DSC_0004 by alwaysdeployed, on Flickr
I used my air grinder to cut both sides out. A dremel will work also. I avoided the wires by moving them as i cut
[IMG]DSC_0025 by alwaysdeployed, on Flickr[/IMG]
[IMG]DSC_0031 by alwaysdeployed, on Flickr[/IMG]
After i cut out both sides i cleaned the metal with a grind stone. Once again a dremel will work also
[IMG]DSC_0033 by alwaysdeployed, on Flickr[/IMG]
When both sides were done, i went back tot he top to drill the holes. I used a 1/4 inch drill bit and i taped off the area so i would not scratch the paint. Use cation when drilling on the drivers side, watch the wires
[IMG]DSC_0044 by alwaysdeployed, on Flickr[/IMG]
[IMG]DSC_0046 by alwaysdeployed, on Flickr[/IMG]
After i cut all 4 holes, i test fitted the wing to ensure fitment
[IMG]DSC_0048 by alwaysdeployed, on Flickr[/IMG]
With this wing, i had to cut a separate hole for the wires so i did that after the other holes and i sealed the hole with silicone and a rubber grommet so there would be no leaks.
[IMG]DSC_0052 by alwaysdeployed, on Flickr[/IMG]
Once you get everything test fitted, attach the 4 nuts to the wing. I used silicone and an anti-rust spray on all 4 holes to ensure no leaking and no-rust
[IMG]DSC_0058 by alwaysdeployed, on Flickr[/IMG]
Once you are done tightening everything up, splice the wire into your brake lights and you are off and running.
[IMG]DSC_0059 by alwaysdeployed, on Flickr[/IMG]
[IMG]DSC_0062 by alwaysdeployed, on Flickr[/IMG]
Hope this helps anyone wanting to try this. It took me about an hour with air so i would guess about an hour and a half with a dremel.
Procrastination is a THIEF of time!!
MY MRT
http://www.cb7tuner.com/vbb/showthread.php?t=203992
My First CB7
http://www.cardomain.com/ride/705233/1990-honda-accord/
dahubby is offline   Reply With Quote
Old 05-29-2014, 09:22 PM   #2
tm123
tm123 is cool... so far.
wow that looks sick! nice DIY
-Tyler
tm123 is offline   Reply With Quote
Old 05-29-2014, 10:29 PM   #3
DCB7
DCB7 is cool... so far.
Props on the brake light work especially
DCB7 is offline   Reply With Quote
Old 05-29-2014, 10:57 PM   #4
dahubby
Thanks i appreciate it, I love it
MY MRT
My First CB7
Old 05-29-2014, 10:58 PM   #5
dahubby
Thanks man, it was actually pretty easy, i hated to cut my cb though...lol
MY MRT
My First CB7
Old 05-31-2014, 01:26 AM   #6
F20A CB7
Nice to kno u r doing diys and sharing it on the forum. Thanks.
Old 06-22-2014, 06:38 PM   #7
jasen klems
jasen klems is cool... so far.
nice job I would not have made such a large cut on the underside of the lid. I would suggest that you drill all the way through and then on the underside use a hole saw and make the holes larger so that you have a more factory appearance. Just my 2 cents on that. your install looks great man
jasen klems is offline   Reply With Quote
