Recently I got CEL's 14 which is the IACV and 6 which is ECT, engine coolant temp sensor.
I checked the coolant temp sensor's ohms and it tested to be in perfect working order. Same with the IACV.
IACV was 13.6 ohms and 11.89 volts with the ignition on ACC and engine off. So it was within spec.
Then I stumbled on this thread: http://www.cb7tuner.com/vbb/showthread.php?t=183897
So I pull the ECU out and have a look. I find D13 to be burnt.
I installed another PT6 and it burnt D13 in that one too within about 5 minutes.
I have read that D13 is for IAB's. PT3's don't have anything in the D13 spot which is what I have in the car now.
I checked to make sure the IAT and IAB plugs are not switched.
The thermostat ground is also connected, clean and secure.
The IAB wiring seems to be good. What could be causing this?
