BLK/WHT passes through the fuse box to the switched side of the starter relay. Fuse 9 sends power to the clutch switch, which then goes to the low side of the starter relay. Check fuse 9 first (easier), then track down the relay.
wont start with key, will start by jumping starter..
You can unplug it. I removed mine and everything works fine with no CEL.~Nick~
Originally posted by Slammed Accord View Postok, im at my wits end.. my car wont start with the key, it was working fine stopped to get lunch and it wouldnt start again with the key.. i can jump it at the starter and it starts and runs fine.. i have power to the switch, when i turn the key it sends power from the switch, im now at the clutch switch which im not sure if it is a pos or neg for the clutch switch.. also my plug for the clutch switch only has 2 wires. (M/T) but has spaces for 3 wires.. i think i checked all the relays but im not sure.. i just want to drive my car.. im so streesed out with life i need to cruise my bad ass accord to destress... its not my daily, its my toy.. its what i use to get away on a fast road and use the 2000 watt amp and the 4 12's so i dont put a gun to my head... lol please help... i need to take that drive.. Thank you in advance for any help...
understand what you mean about your CB being your way to get away from
life for a while. But take it easy man! Life definitely can get tough. I know
you don't know me but if you ever need to vent to someone or get shit
off your mind you can reach out to me. I had a horrible year & two of my
car buddies who aren't really that close helped me out a bunch.Keep Pushing..
Lol yeah don’t commit toaster bath just yet. Just follow the diagrams provided, verify voltage and good fuses. It’ll come together & be something simple to fix.
Have you tried just jumping the clutch switch?
I know you said you have new bumpers in the pedal, but double check that they’re still there.
I used an 8mm bolt/nut to replace both of them when I was rocking a CB. It’s a sure fire way to make sure it never happens again, but if you do that, adjust the switch so that you don’t break it when you depress the pedal.
Don't let it get you down. Think of it as an opportunity to learn more about your car.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
