Go Back   CB7Tuner Forums > Parts & Performance > Performance Tech > Naturally Aspirated
Old 09-09-2019, 07:22 AM   #1
tgdrums1990
tgdrums1990 is cool... so far.
Send a message via AIM to tgdrums1990 Send a message via MSN to tgdrums1990 Send a message via Yahoo to tgdrums1990
Mild F22 Build P2V Clearance / Camshaft Regrind Help
In process of a mild f22 extreme budget build.
A6 / H22 Hybrid Intake Manifold
F22A1 Head with .030 milled off the head.
Stock F22A1 block ( Not Touching the bottom )
And I just shipped my camshaft to delta. I have not decided the regrind yet.
A member on here shared these specs sometime ago.
Bisimoto level 2
intake opens ATDC: 4deg
intake closes ABDC: 44deg
exhaust opens BBDC: 41deg
exhaust closes ATDC: 1deg
intake duration: 220deg
intake centerline: 114deg
exhaust duration: 222deg
exhaust centerline: 110deg
overlap -3deg
measure valve lift in/ex: .405"/.392"
My custom web
intake opens ATDC: 2deg
intake closes ABDC: 46deg
exhaust opens BBDC: 44deg
exhaust closes ATDC: 4deg
intake duration: 224deg
exhaust duration: 228deg
overlap: 2deg
measure valve lift in/ex: .430"/.417"
Curious if the Custom Web specs provided would be too much lift with .030 off the head and stock pistons.
Also im on the hunt for a adjustable cam gear for all of this mess I created for myself. Gusse they stopped making them a while ago
Thanks again.
tgdrums1990 is offline   Reply With Quote
