Go Back   CB7Tuner Forums > Parts & Performance > Audio/Electronics
Old 10-19-2019, 02:12 PM   #1
andrewdink
Foundation Member
andrewdink is cool... so far.
OEM CD player Accessory Pinout
Im back from the grave!
I got another 92 and am working on doing a full showroom restoration. I got the Honda Accessory CD player 08A06-121-210, however someone cut the harness off at the connector. Here is the question, with the CD player there is supposed to be a Y-Harness that goes from the vehicle harness on one end to the split where part goes to the Radio and part goes to the CD player. The color of the leads on the CDP player does not match any of the colors in the vehicle harness and no surprise but the Y-Harness has been discontinued. Does anyone know what the Pinout is supposed to be so I can create my own harness? I don't want to splice or cut any wires, going for clean factory like install. Thanks so much!
Current
1992 Accord EX 5-speed Sedan
Rosewood Brown
1992 Accord EX 5-Speed Sedan
Arcadia Green
Previous
Bordeaux
1993 Accord LX 5-Speed Sedan
Bordeaux
andrewdink is offline   Reply With Quote
Old 10-30-2019, 02:45 PM   #2
andrewdink
Foundation Member
I got answers
Alright folks, through a stroke of luck I was able to find an OEM CD player with the needed harness so thought I would share the knowledge I was looking for.
OEM CD Player 08A06-101-210
Following wires come from it
Yellow/Red
White/Blue
Black
White
Orange
Brown
To connect these to the car without the the proper connections on the CD player the following must be done.
On the vehicle Harness:
Yellow/Red - Pin 4
White/Blue - Pin 5
Black - Pin 11
At the Factory Radio
White - Pin 12
Orange - Pin 13
Brown - Pin 14
I plan to create my own harness by getting a a factory replacement harness such as the ones here:
https://www.carid.com/1992-honda-accord-wire-harnesses/
And adding the pins as needed for the 12-14 using a pin kit, and repining 4, 5, and 11, with two wires instead of one exactly as the OEM harness on the CD player would. I will share documentation with the process when I get the opportunity to complete it.
Current
Rosewood Brown
Arcadia Green
Previous
Bordeaux
Bordeaux
Old 10-30-2019, 03:19 PM   #3
fleetw00d
I may have a player that no longer works, I could cut the harness off it (or send you the whole thing).
90 LX 4dr 5 spd 385,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
07 Element EX AWD 192,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210623
07 Element EX AWD AT (2) 87,000 - MRT: www.cb7tuner.com/vbb/showthread.php?t=211920
LOTS of CB7 parts - ENTIRE COLLECTION - FREE
Come and get it.
http://www.cb7tuner.com/vbb/showthread.php?t=192583 or watch for banner ad at upper right
08a06-121-210 , accessory radio , oem radio
