Custom Strut / Firewall Brace
Looks good and all.. how did it feel after install??
the only thing that itches at me is the fact that its not entirely equal length.. the passenger side tubing that goes towards the firewall is made up totally different than the drivers..
if u look at neuspeed's 4pt bar.. ull see that both sides are entirely equal.. good job though none-the less.. why didnt u make both sides equal?
edit.. also.. since u made an opening in the arm that connects to the strut circles.. it would be optimal for u to add braces from that piece to the other 2 nut area's... just to reinforce it.. i dunno im anal about shit like that..Last edited by WiKKeDV16; 04-28-2005, 01:12 AM.
Praise The Lowered...
there are two M6 bolts that stick out from the firewall. I fastened a plate to those.Originally posted by timmy0toolwow that is a GREAT piece you got there buddy! what did you use to brace it to the firewall? this should tighten up the chassis.
SOH CAH TOA is your friend for life. you'd be surprised how often you may use it.CB7 + H22A4 + M2S4 + JDM P13
www.vancouveraccords.com
cost me nothing, just time. we have a full machine shop where i work.Originally posted by arrozburnerthats pretty cool...make a polished one and i'll take it! how much did it all cost you to make?Last edited by Wallace; 04-28-2005, 01:19 AM.CB7 + H22A4 + M2S4 + JDM P13
the reason it's not symmetrical is because of the clearance issues. the peice on the passenger side has to clear the TB, whereas the drivers side does not.Originally posted by WiKKeDV16Looks good and all.. how did it feel after install??
i was worried about the openings as well. but i tested the strength and rigidity before and after i made the holes, and there was no noticeable difference.
i havent had a chance to really test it yet, i just put it on a couple hours ago.CB7 + H22A4 + M2S4 + JDM P13
