Thread Tools Rating: Thread Rating: 27 votes, 5.00 average. Display Modes
Old 07-02-2005, 09:27 AM   #1
cp[mike]
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
SUSP : 5-lug conversion (the all-prelude way)
With all the talk about 5lug conversions, i figured id finally get this up, just to have it out there. if you know what youre doing you can figure it out pretty easily, so youll just have to manage until we are able to get pics up.
BACKGROUND INFO:
why search down mixing and matching odyssey/lude/accord parts when finding a lude and grab the whole shebang works just as well? excalibur02 managed to get a 99 lude parts car, so viola, all the 5lug conversion parts we needed were there. including crossmembers and stuff, which lots of people think you need - you *dont*
CREDIT:
the original idea for this came from mayberry's car, he bought his car with the front 5 lug using prelude parts... but we didnt know exactly how it was set up. THEN excalibur02 wanted to do his, so i helped him out, and what you see below is the result. all pics (when they get posted) are of excalibur02's car.
NOTES ABOUT THIS CONVERSION:
* * READ THE ENTIRE THREAD FOR MORE DETAILED INFO * *
- use non-SH parts! the knuckles from a lude SH will not fit.
- the way the upper control arm sits with the new knuckle, this mod will give you POSITIVE camber at stock height. if your car is lowered, it will most likely push it out and return your camber to just about STOCK without the need to use a camber kit in the front. if you have a camber kit in there now, youll need to remove it, or readjust it!!! with mauri's car, putting stock upper control arm anchors back in was perfect enough to have his camber go just about dead on after this conversion.
*****PARTS NEEDED:*****
- front knuckles (with bearings and hubs still in em) from 97-01 prelude
- rear hubs and bearings from 97-01 prelude
- pair of front rotors for 97-01 prelude
- pair of rear rotors for 97-01 integra type R
- recommended new pads all around, match them to the calipers you use (front = prelude and rear = accord)
- driver side axle from a 5th gen accord (correct tranny type matters)
FOR THE FRONT:
Basically, just pop the lower ball joint, upper ball joint, and tie rod. remove everything connecting the knuckle to the car.
when directly reinstalling the prelude knuckle in place of the accord one:
- The accord upper control arm ball joint fits into the lude knuckle. or you can swap over to lude upper control arms if they are newer, both work
- important: stock tie rods mount under the accord knuckle. they mount OVER the prelude knuckle. SO: remove both tie rods and reinstall them on the opposite side, facing the other direction. so the LEFT side tie rod which normally faced up should be on the RIGHT side facing down. do for both sides. if your tie rods are bad, now would be the time to replace them.
- swap in the 5th gen accord driver side axle - the accord one is too short, and the prelude one is too long. 5gen one works perfectly. your stock PASSENGER side axle is fine, leave that one alone.
- LOWER BALL JOINT - the lude uses a larger ball joint with a 19mm nut, the accord uses smaller with a 17mm. SO youll need to either find a way to swap the accord lower ball joint into the lude knuckle, or if you were mauricio, use a grinder and expand out the hole of the lower control arm to accomodate the larger ball joint. there is a reamer tool available designed with the proper taper for balljoint studs, for this very situation: Ball Joint Reamer (thanks 90accords)
FOR THE REAR
BustedLX made the official rear 5lug conversion thread, follow that: http://www.cb7tuner.com/vbb/showthread.php?t=16241
mauricio has an LX with rear drums, so after swapping to rear discs, he still doesnt have ABS so the excitor rings and sensors dont matter for him. if you have an EX with ABS/rear discs youll need to follow busted's guide (NOT THIS ONE) and do a little more work. but basically the same thing.
for you LX's who converted to rear disc who are doing the 5lgu conversion:
Take off the 32mm nut holding the stock 4lug bearing/hub onto your car. do the same for the prelude bearings/hubs. youll notice the lude and accord ones are similar enough to just slide the new 5lug prelude bearing and hub back onto the car and put the PRELUDE nut back on.
the ONLY special thing you need is a set of rear rotors for a 97-01 ITR.
Thats all I can think of right now, pictures will come within the next few weeks.
any questions feel free to ask, me and mauricio will probably be able to answer any questions.
- 1993 Accord SE - Gold coupe
- 1999 CR-V EX - Daily driver
Old 07-02-2005, 05:36 PM   #2
k-mart
k-mart is cool... so far.
thats great guys, awesome work with the trial and error
k-mart is offline   Reply With Quote
Old 07-02-2005, 06:54 PM   #3
BustedLX
BustedLX is cool... so far.
I'll add that the reason people swap over the 5th gen lude's lower crossmember is because they use the 5th gen's lower control arms to accomodate the larger ball joint.
Personally the expanding our smaller lower control arm with a grinder or whatever is a rig. I wouldn't do it. If it IS possible to press out the Prelude's lower ball joint and replace it with ours then I would deffinately do that for two reasons.
A) It would make the swap easier because of the less parts to change (lower crossmember, control arms, etc.)
B) The Preludes lower ball joint according to Honda is not replaceable, you have to purchase the entrie knuckle sooooo that blows.
If you can press out the ball joint and swap it that's a plus... but if you think about it.... then that's as much if not more work then just grabbing Odyssey parts.
It is great that you have presented this option... and for those who have access to the parts cheap that's good. But on the norm... 5th gen Prelude parts from the junkyard are pretty costly, whereas Odyssey and 2nd gen Legend stuff is a dime a dozen. Atleast the parts we would need.
Anyhow I look forward to the pictures, keep up the good work.
BustedLX is offline   Reply With Quote
Old 07-02-2005, 08:15 PM   #4
jeesare
jeesare is cool... so far.
Agree with you Jose, I used Odyssey/Oasis knuckles. A lot faster and cheaper.
jeesare is offline   Reply With Quote
Old 07-02-2005, 11:27 PM   #5
SSMAccord
yeah, while this method a viable option, 5th gen prelude stuff is a little rare to find in the salvage yard and would be a little more expensive, but if it does offer the benefit of camber correction it would have something in its favor. (i think that the 'lude upper A arms are shorter than accord parts which accounts for the camber correction.)
I went the odyssey route for knuckles, but great job on finally figuring out how to make it work !
Old 07-04-2005, 04:59 PM   #6
timmy0tool
Accord of the Month: April 2006
timmy0tool is cool... so far.
Send a message via AIM to timmy0tool
wow more people are taking initiatives; I LOVE IT! good job on that mike! when i had my 5th gen lude knuckles i saw that i couldn't just use them. there were TWO lower ball joints on the them. i later found out that the lude was an SH model. i don't think you mentioned this but you will need to use non-SH lude parts for this DIY.
SH prelude
non-SH prelude
now i just wish the lude knuckles i had were non-SH. it would have made my whole conversion much easier.
1cor10:31
- 92 LX coupe
- 96 EX wagon (sold)
timmy0tool is offline   Reply With Quote
Old 07-04-2005, 08:18 PM   #7
MDIZZLE4SHIZZLE
MDIZZLE4SHIZZLE is cool... so far.
Send a message via AIM to MDIZZLE4SHIZZLE
so about how much will the whole set-up cost (for the parts) cause i want to do this, when i get mo money and get 05 rsx type s wheels. and will s 2000 rims fit our cars with no problem, cause i know that thats rear wheel drive.. thanx
THIS ONE HERE IS CRACK!!
MDIZZLE4SHIZZLE is offline   Reply With Quote
Old 07-04-2005, 08:30 PM   #8
k-mart
you need four fronts
Old 07-04-2005, 08:39 PM   #9
MDIZZLE4SHIZZLE
ok but they will be all good to go eh???
Old 07-04-2005, 09:00 PM   #10
BustedLX
I don't know about needing the four fronts, has anyone really tried this?! I think if I get motivated tomorrow I might swap wheels with my Bro's S2K and see what it looks like. I think putting the wider S2K wheels up front might look cool.
Old 07-05-2005, 01:02 AM   #11
excalibur02
Wanna be JDM whore
wow. didnt know u made this already mike. well as u guys read. i had a totalled prelude. so the parts for me was lol there. thats why i wanted to know how i would be able to use prelude parts instead of spending more money on odyssey parts.
thanks mike, and eric
Instagram username MAURO02
Old 07-05-2005, 01:18 AM   #12
clarksterdotcom
clarksterdotcom is cool... so far.
i dont know about the S2k wheels but i know the NSX wheels are different and you need four fronts.
but sounds good mike i know its harder out here to even get lude parts so im glad if i find 1 lude i can rip through it and get all my parts in one place.
clarksterdotcom is offline   Reply With Quote
Old 07-05-2005, 01:32 AM   #13
jdm91cb
jdm91cb is cool... so far.
Send a message via AIM to jdm91cb Send a message via Yahoo to jdm91cb
1 again Mike awsome job bro sweet
LEAVE NO DOUBT!
If God is for Me
Who Dares be aganist Me!
BX Crew
HSHO # 6
Lexotic Concepts 019
jdm91cb is offline   Reply With Quote
Old 07-05-2005, 05:38 PM   #14
k-mart
i have found that everyone, and i mean everyone, says to use four fronts. and i have seen, but of course never tried, them on almost every honda/acura imaginable. from a legend to a 5th gen accord, to the 92-95 civics (all body styles), ITR, 97+ lude, you name it, lol. well, w/ the exception of a CB.
ive heard of people trying to fit the 7.5" wide/ 65 offset rear wheels onto the rears of their ITR's and they all have said that the rim hits the trailing arms. im not sure about using them up front, but that is where you come in man!
let us know, and take pics!
Old 07-05-2005, 05:56 PM   #15
uncle_el
Moderator
uncle_el is cool... so far.
timmy0tool has a set of wheels that are 8" wide with a +58 offset and a 225 series tire, and they won't fit for driving.
the s2k wheels aren't as wide, but have a high offset (not sure if it is +65 or not). makes me think that at the very least, it would be cutting it close. it would be interesting to see if they could work though.
uncle_el is offline   Reply With Quote
Old 07-05-2005, 06:04 PM   #16
k-mart
sorry, i believe they are indeed +65
make it happen Busted
Old 07-06-2005, 02:57 AM   #17
timmy0tool
the specs are correct but actually today i found out that they DO fit, but only in the front (the knuckles in the rear come closer to the outside). i used a 5mm spacer and it was barely rubbing against the knuckles. and i mean barely like i can only slide a piece of paper between the tire and knuckle.
i don't think s2k wheels will fit without major modification. prove me wrong someone ! busted?
1cor10:31
- 92 LX coupe
Old 07-08-2005, 09:01 AM   #18
cp[mike]
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
stupid thread hijackers!
anyway mauricio did most his rear disc and 5lug conversions last night... almost done... hes been taking pics so he will have pics to post soon
busy guy hasnt even had time to post in his own thread really which i remind you all, this wasnt my conversion, i just helped with it. so stop giving me all the credit
Old 07-08-2005, 11:47 AM   #19
excalibur02
Wanna be JDM whore
GOSHHHH!!!!!!! stop giving him all the credit.... my lips hurt. mike can u bring me chapstick. goshhh its hurts!!!!!!
Old 07-25-2005, 10:44 AM   #20
timmy0tool
bump! where is the update?!
1cor10:31
- 92 LX coupe
