I am not responsible for anything that goes wrong with this install... with that said lets began.
Tools/supplies:
-6th gen civic lip (CTR lip use)
-12mm socket
-extension
-socket wrench
-drill
-drill bits
-screw driver
-cut off wheel
-air compressor
-self tapping screws
-scrap metal/sheet metal
-sand paper
-nuts and bolts
First remove front bumper, Link to ucs DIY Here
Cut a line in the bumper the size of the flap on the lip (circled) using the cut off wheel or whatever you have to cut with.
Clean up the cut with some sand paper
Then cut small strips of metal to screw into. I used aluminum tubes that are use in radiators because I work for Modine who just so happens makes radiators. You can use anything really just as long as the screw has some thing to hold onto. Drill a hole into the metal just smaller then the screw so the screw grabs the metal instead of just sliding through.
this what the little strip is used for helps hole the lip on the bumper by spreading out the weight and also giving the screw something to grab onto
Tools/supplies:
-12mm socket
-extension
-socket wrench
-drill
-drill bits
-screw driver
-cut off wheel
-air compressor
-sand paper
-nuts and bolts
but hey thats what we call it a DIY
